Need help with sysmetrix dual state images and weather wind speed problem
I am having a problem getting a set of dual state images to work correctly. I have a set of images that I want to use to show if there is a disc in my cd-rom and dvd-rom. The first image is of a drive and the second is of the drive with a disc super-imposed over it. I sized both images to the size I want them and put them side by side in 1 image. I then named the image "DiscInserted.png" as needed. The problem I have is that the in either state the image shows half of the first image and half of the second image.
I no matter what I try to do I can't get seem to get the image spacing correct. Can anyone help with this problem.
The second problem is with wind speed. How can change the speed from km/h to mph or knots?
1,559 views 5 replies
Had this prob myself,make sure the images are of equal dimensions and there is no excess background as this also adds to the size of the finished image
ok, will give it a try, thanks, you the only person who has replied to any of my messages on this board. So special thanks!
Well I did like you said but it is now showing me half of only the first image. I don't know what the deal is. Doesn't seem to matter what size I make the image either it always cuts the image in half. grr frustrating
Your problem is with the .png graphic. When you are done editing it in Photoshop, go to
file>save for web. Then save as png-24. That will discard any image information that is not needed in Sysmetrix.
[Message Edited]
try making images square with no excess background before ,in middle of or after your two states. two images should be butted up together no spacing
