Tangent/Lightning Problem - Please help *SOLVED*
please could someone help me? I've after long time of peace again encountered a very persistent tangent problem. I hate XSI... or my modelling skills. Or both.
Problem is as follows: the tangent map looks fine in XSI. The vertex normals are angle-weighted vertex normals generated with MeshLabs. Also they are normalised. Mesh uses its own set of UVs, based on a cubic projection and then refined.
In Sins the model is lighted 90 degrees off - if the light comes from the side, the model is lighted from behind. Also the selfshadowing is completely off
Tangent:
Tangent map
Ingame screenshot:
Ingame Screenshot
I'm grateful for any help or advise.
Tobias
58,622 views 9 replies
Tangents in XSI are evil. Sadly I usually resort to redoing them again if I get a weird issue like this where XSI shows one thing and Sins shows another. Maybe Lavo, MyFist, or Max might have more insight if you track them down.
Thanks. I already redid them once including recalculating the normals.
lat time I had this problem it went away after starting a new game. This time it didn’t work.
the first time I had this I had to redo the complete model.
I wish someone could tell me what the reason for such problems is. I hate the xsi/sins combo
Use Property-UItimapper, then Scene-Material-Simple-Tangent 45>180 and can export model, shadows look like normal
Quoting GRAVICH, reply 3
End of GRAVICH's quote
Not sure what you want me to use the ultimapper for. And what is Scene-Material-Simple-Tangent 45>180?
Do you mean I need to change the TangentOp2 Smoothing from 45 to 180? That would change the behavior how light bleeds from one poly to the next. If you like to assist may I send you the file in question and you send me back the corrected XSI file so that I can see what needs to be done?
Tobias
Ok, send me xsi file
Semt it, forgot subject though. :blush:
I  am so stupid!! I forgot to copy the red channel of the normal map to the alpha channel. :blush:  X|
Quoting TobiWahn_Kenobi, reply 7
End of TobiWahn_Kenobi's quote
Wow, I had no idea it could make that big of a difference.
Quoting GoaFan77, reply 8
End of GoaFan77's quote
seems drastic, doesn’t ist? But if we equate different grayscale values to different vector strength then having everything white throws the light equation off by quite a huge amount
