background and text color changing of some parts
hey there,
i'm using windowblinds 8 with the 'electro sexual' skin and i'm loving it but i can't seem to find the right color to change.
i uploaded a picture to show you what background and text i mean. it does look great actually but you sometimes cant read text written on it.
i looked for it in skin studio and the windowblinds settings but didn't succeed in finding it :(
i'd be ok with changing the text colors in both cases, if they apply globally and only with those backgrounds (i hope you know what i mean)
i appreciate any help :)
http://www.pic-upload.de/view-21629739/wb-color-prob.jpg.html
thanks, enaecore
ps: i also have some issues when transparency is enabled in windows settings. text in explorer windows (files, folders) isnt readable then and when i select items the selected area becomes transparent o_O
using windows 7, windowblinds 8
2,470 views 4 replies
:cylon:
Unfortunately those are fixed system colors that you just have to live with when using a dark skin.  There is nothing you can do about it. :S
Quoting maxschwartz, reply 2
those pitily don't change the desired colors.
End of maxschwartz's quote
Tried my best, too bad it was of no help to you Max... :S
