Salt Water Motor will be sold and shelved
where did they all go?
http://www.youtube.com/watch?v=GICYKU80SQA
ok. so this is from 2007... where the hell is it?
this guy seems to have solved pretty much all of our fuel problems.
You cannot get much more abundant and easy than salt water.
But at the end of the clip it says he is willing to sell to some "large company".
I hope now that its public this will not be shelved.
Other problem is it could destabalise the world. think the bigwigs are gonna let their oil investments go down in flames?
edit: http://www.youtube.com/watch?v=x1UrlDNkYSo&feature=related
what happens to this stuff?
there are so many of them out their. Different ways to power cars effectively. My point is that each one invented and patented is another one shelved making it harder to actually produce a new way that may actually have a chance of not being shelved.
http://www.youtube.com/watch?v=KZOsOB3z3IE...feature=related
http://www.youtube.com/watch?v=65RkcDZxPuQ...feature=related
http://www.youtube.com/watch?v=tBm8ogwnpG0...feature=related
http://www.youtube.com/watch?v=9ubY25mClGQ...feature=related
28,922 views 12 replies
/me laughs, and recites the laws of thermodynamics.
It doesn't use saltwater, or city water, or drinking water, or water of any kind...  It uses hydrogen to power the engine, a technology we've had for a long time now, especially since he was using a hydrogen engine in the first place.  And their claim of no maintenance is pure bull when you consider that the reaction of splitting the oxygen from the hydrogen would leave salts and other mineral deposits in the reaction chamber and on the electrodes thus reducing it's capacity and ability at every use.  That's also if you completely ignore the fact that no matter what, all moving parts and seals eventually break down or the off chance that something wasn't machined or installed properly leading to catastrophic failure of some part of the system, primarily the engine itself.
Granted it looks like a video from the 80's, confirmed by their mentioning the government's star wars program, but the simple fact of the matter is, the industry won't change until their current power source, namely oil, is no longer so readily available, or until consumers no longer are willing to buy from that source.  Also what complicates that engine is the fact that in the mid 80's when he was riding around in that thing, a gallon of gas in the States was under a $1, making that type of engine a novelty at best.
Presently, the reason why he can't sell it is because the auto industry has already spent it's time and money on hydrogen power, and here in California, the oil companies have even been spending money to install hydrogen fuel stations.  Why take the time to screw around with that and buy it when you've already done the R&D for it's real working components before that machine was ever on the news, and already planned for funding and building up the infrastructure to supply the fuel when the time comes to switch to it?  That's why you haven't seen it and wont ever see it in that form.
Any claims of an engine that "runs on water" are probably 99.9999% bogus.  Why is that?  Because water contains very little potential energy.  There isn't much energy that you can get out of it.  Water is very stable.  What exactly does it chemically react with other than perhaps organic chemical radicals?  You can't burn water; it's a combustion product.
Quoting DirtySanchezz, reply 3
End of DirtySanchezz's quote
Like burning ash. :P
mmm... ash is carbon... it burns rather well if you know what to do with it.   c02 more stable than graphite.
The analogy still works. Ash by itself doesn't give you much energy like just like water. However, using certain techniques you can use ash to create charcoal which is far better then wood at creating heat/energy. Same with water. Put a fire under it (nuclear/coal/oil/etc.) and then use the steam in a turbine to turn a generator and produce energy.
ok. that analogy definatly doesnt work.
but ya. no. thats not a "salt water moter"  All your doing there is either seperating the hydrogen and oxygen, and immediatly recombining them.... or a similar process with the Na-Cl.  that radio emmiter is supplying all the enery... and you would need say... a preeeety massive generator to run that radio emiter.  So ya... you would have to be a fking retard to think this was a good way to run a car.
Now. if its is seperating hydogen and oxygen... it would be certainly be interesting to see if its a more effective way to create hydrogen than the current methane decompsition process used... (which, creates C02)... but i doupt it.
THe second link isnt even the same technology.
Thats just a fuel cell.
Third link is something completey different as well.
The "water powered torch"  thing, is NOT water powered.  it is powered by the oxidation of the metals themselves.  ya, hes heating those metals up crazy fast, but he is turning them into MOLTEN BLOBS OF RUST in the process.  Its like thermite.... but less usefull.
...      UNFATHOMNABLE STUPIDNESS.
look.
I am doing some research... in something completely unrelated... but part of that research is using the same technology these guys are using.   I could turn it into a "water engine" by doing little more than simply applying a flame to the surface of the water.... but the quantity of electricy I am using FAR FAR outways any possible enegry generation from it.
YOU CANT BEAT PHYSICS.
Quoting Pbhead, reply 5
End of Pbhead's quote
The difference is that water molecules already contain oxygen.  2H2O + O2 ---> 2 HOOH (hydrogen peroxide).  The problem is that producing hydrogen peroxide from water and oxygen isn't an exothermic reaction.  The chemical potential sends it to the water side of the equation.  In contrast you can take Carbon and add Oxygen to it.
Quoting Ryat, reply 6
End of Ryat's quote
The difference is that the energy is being released from the ash/coal.  In contrast, in a steam turbine the energy is being released from some fuel source and it heats up the water.  The water just acts as a carrier for the energy, but it's not the source.
Let's assume that you can break water up into hydrogen and oxygen with 100% efficiency, then burn the hydrogen also with 100% efficiency.  What you'd have, at best is zero net energy output.  Of course, it won't be 100% efficient, so instead of having energy generation, what you instead wind up with is an energy hog, a further burden on our energy usage with no gain at all.
There's an old joke that says that the three laws of thermodynamics are:
1. You can't win.
2. You can't even break even
3. You can't get out of the game.
The rule of thumb is that if it sounds too good to be true, it probably isn't true.
compressed air cars are real, being made in china, India, Australia and Europe.
An ex mercedes benz engine designer from australia invented a rotary air powered motor for use in agriculture equipment and has been licensing it out to people who will produce vehicles using his engine.
What powers the compressor you might ask?
Solar panels.
Tried, true, and i've seen them work myself.
The range of these vehicles traveling normal speeds is roughly double the range of a gas efficient vehicle.
Water power isn't the answer, too much difficulty.
sareth got links?
