Draginol Draginol
Monitoring your home power usage with TED
The Energy Detective is a kit that you can purchase online that lets people monitor how much power their house is using in real-time.  While there are newer kits that work with your power meter, many advanced power meters (such as what I have) won’t work with them.
The way TED works is as follows:
The measuring “donuts” hook up inside your electrical panel. These donuts then are connected (and powered) by one of the breakers. The electrical line connected to the breaker is used to send a signal to a remote “gateway” that can then be connected to your router.
Hooking this up is, unfortunately, non-trivial if you’re non-technical, especially if you’re not familiar with electrical equipment or have an electrician at your beck and call.
My Installation
My house has 4 different panels so I used their highest end model that came with 4 sets of “donuts” that connect to their MTU (the gadget that records the data and sends it out to the gateway.
Now, the documentation for TED (and the help forums) assume that the people doing this sort of thing can, on the one hand, afford a $500 gadget to measure their power output but on the other hand assumes the user is going to be unable or unwilling to spend a relatively small amount to make it easy to hook up.  As a result, there are a lot of aggravated users on the TED forums.
The main reason: The power line communications choice that TED uses.  Basically, TED sends its signal from its MTU to its gateway over your power line. This makes it very vulnerable to electrical interference and weak signals.  Even if you overcome this, odds are, it by itself will interfere with other gadgets are that using the power lines to communicate as well (security systems and other smart home features).
I decided to bypass this pain by spending an additional $100 on two things:
1) An additional circuit breaker + power outlet dedicated just to this.
2) Netgear WNCE2001 Universal WiFi Internet Adapter
These two things bypassed many many pages of frustration you’d get under normal circumstances.
The first is so that you have a clean line from your donuts/MTUs directly to the Gateway.  The second is to make it easy to get the Gateway data to my wireless router.
photo 1
This is the Netgear Ethernet to Wireless adapter which I hooked up to the TED gateway.
photo 3
This is my crappy setup. I’ll clean it up later once I’m satisfied it’s working.  Basically, all 4 donuts/MTUs output to a single line that goes to the outlet that the gateway is plugged into. By doing this, I bypass all the line noise nonsense/interference with my security system that I’d get if I tried to have it use a regular outlet. I had an electrician come over and install the outlet I needed.
photo 2
This is my breaker box after I unscrewed the cover that hides the spaghetti. So those two donuts go around the black and red lines and are connected to the TED “MTU” (measuring gadget) that is then powered/connected to one of my breakers which is fed to a dedicated power outlet.
TED also has a decent real-time measuring system that you can see below.
Now, I picked this up because I was trying to figure out why my house is using so much electricity.  The big yellow jump there is the geothermal turning on that heats our pool room.  The blue line is the total amount.  The light blue line are the lights, control 4 and home automation controls. The pink is something I’m still investigating but mostly has to do with our kitchen (my wife was making dinner in our electrical stove during this).  The green I’m still trying to figure out what’s using that.
Verdict
If you’re pretty technical and not afraid of of messing with your electrical system a bit, TED is a good choice. I will admit that my casual/careless nature (you saw the picture above) meant I experienced a few shocks. You need to be careful when doing this kind of thing – more careful than I am.
If you can use a system that works with your electrical meter outside your house, I’d recommend that.  But for the large % of people who, like me, cannot do that then TED is really your only option.
73,037 views 31 replies
Australia [mostly] has dumb meters....dials that go round and round and don't care where, what, why or when you're using juice...just how much so they can charge you for it.  We're in the throes of getting more 'intelligent' ones.... that can discriminate 'when' so as to charge overly MORE for peak usage so as to dissuade people from using as much at peak and thus put off bringing more stations online.
Of course.....the COST of the meter upgrades would cover the price of a new Power Station...but you know, Logic is never a Govt's best suit....;p
When those meters came out in Canada there was a government rebate for while. Power cost go up like everything else does and it is an investment if you want to save in the long run.
Power hogs should pay for polluting the planet.
Our system is about to crash its so old, just wait to see the cost increases then along with blackouts like a few years ago that took out the east coast of canada and the u.s.. 3 days without power and watch your friendly neighbors turn into thugs.
Development of a National East-West Power Grid Plan
POLLUTION DEATHS FROM FOSSIL FUEL-BASED POWER PLANTS
3. Australian fossil fuel-based power pollution deaths.  The data in  #2 suggest that coal plants producing 77% of Australia's annual 255 TWh of electricity from 51 GW capacity (i.e. 0.77 x 255 = 196.4 TWh/year; see: http://www.uic.com.au/nip37.htm )  might kill about 196.4 TWh x 668/27 TWh = 4,859 people annually in Australia (population 21 million); in Australia 255 bn kWh x $0.04/kWh = $10.2 bn; 0.77 (coal-based) x $10.2 bn = $7.85 billion; $7.85 bn /4,859 deaths means that Australian electricity consumers pay for electricity @ $1.6 million per fellow Australian killed by coal.
But WTH, my pool needs to be warm.  }:)
@NoNoun, you're extrapolating way way too much from a screenshot.
There were lots of things I did besides cut down the geothermal from the pool. I think I listed some of them in another post but for instance, Control4 has an "evening lighting" program that goes on after sunset that used a lot of power. I reduced the # of lights on when that program activates.  I turn off our theater room components completely when not in use which saves 24 KW/h a day.  I reduced the amount of hours a week the pool filter is on, and so on.
I should also add that power usage doesn't scale with house size.
The biggest energy use in our house at this point comes from refrigerators. Everyone has at least 1 refrigerator.  Even in a much bigger house they probably still have the 1 refrigerator.  Unfortunately, in this house we have several.
We also have all LED lights which takes us from 60W per light down to 8W.
The way I look at it is that our house has 5 people in it.  We shouldn't be using more than 5X as much energy as a single person.  So I'm focusing on right to reduce our energy consumption as much as possible.
myfist0 ....we have tree-hugging hippie-crappers complaining about ecologically SOUND alternatives to fossil fuels....which can be pretty bloody frustrating for a country that has the world's biggest/cheapest coal resources [and thus dis-incentive to change].
There's some bloody perrot that is calculated MIGHT be a victim of a wind farm 'prop' maybe once in 100 years....so heck no..... VETO THAT.
Meanwhile....people [and animals] die from effects of coal usage.
Yes, it's all so sweet and logical.
But if a tree-hugger shows photos of something small and furry clubbed to death by technology all the bleeding hearts cry in unison.
Blue-bottles...seaweeds [surfers] get their board-shorts in a knot over desalination plants...in the [second] driest continent on the planet [current floods NOT withstanding].
As with the oil industry there are just too many 'interested' parties for logic to prevail.
About 9 kwh/day of my bill was heat.
Get a powerful computer. Mine keeps the room it's in several degrees warmer when it's on. :P
:fox:
