Titlebar Settings (double-click / right click) not working
(Vista 64bit, WB6)
I did a search and didn't find anything regarding this - I have Vista 64bit Ultimate and it doesn't seem to allow for the modification of the right click or double click. Those are honestly the only two things I use in all of Windowblinds (yes I'm a schmoe). Has anyone else seen this issue?
2,963 views 6 replies
Am I the only one seeing this issue I take it?
Bueller .... Bueller ... Bueller ...
I think that with WB6 the skin has to be set that way but have you tried the advanced settings of Windowblinds?
The skin must have (i think) the two lines
RightClickAction=4 (roll/unroll)
DoubleClickAction=1 (maximize/restore)
in section Personality
(not sure for the double click but sure for the right click under XP ...)
Try adding them
I tried it under ANY skin and it does work just fine under XP. I'm thinking it's just not fixed yet. Every few months I try it to see if it's fixed yet, guess I'll wait a bit longer.
Maybe there's not a lot of Vista 64bit users that want to change what the dbl and right clicks do for them who knows.
I used to love to change those, but found out on my Vista Ultimate x64 that the functioning was not what was suppose to be happening so I stopped. I haven't attempted to try it with the current build (probably should have before I posted this).
But no, you're not the only one. Have you created a support ticket for this? If not, I would recommend creating one and referencing this post in it.
Edit:
Actually after testing the double-click/right-click options of WB I see that all but 1 option for the double-clicking works. That option is the "show system menu" option. While the right-click options work, there is, however, a slight bug you might say. Every time you right-click the titlebar, the menu shows then you have to click off of it to have that specific WB right-click option happen. Strange behavior it is.
