help help help with background problem
heres the question....
I loaded a particular theme using DesktopX....now I decided that a specific background that I already had looked better with the icons, so I loaded that background instead. I clicked on the "save desktop/theme" button on the DesktopX helper, it says it saved, but if I try and reload the desktop theme, it reverts back to the original background picture...any help with this would be greatly appreciated. Thanks
3,275 views 2 replies
you need in desktopX builder under desktop tab click on Wallpaper button then set the background image to none and disable the radio button. And save the desktopX theme.
in case of that don't works: witch DesktopX theme? could you provide us a link?
I do believe that worked...thank you very much....just and FYI the theme I was using was called SAGE....but all is well now...thanks again
