Sound effects problem
Is there a problem with wb 5.5 sound effects? I noticed that the skin
"encoded" which supposedly has sound effects isn't working. I have checked the override settings section to be sure that the sounds are enabled and they are.
2,404 views 5 replies
Well you have the opposite problem with encoded that I have. It won't shut the sounds off like its supposed. Also WB5.5
The WB4 version of Encoded has sounds; sound effects are not enabled in WB5+ skins.
Well I am using the WB 5.5 version of Encoded that just came out and it has sound effects. There is also a version for WB4.6 of encoded however I have not installed that so I am using the one just recently updated by the author. My issue is that the sound effects won't turn off like they are supposed to do. There is an option in WB to turn off sound effects and it isn't working. I turn them off, yet they remain turned on.
Hey GhoS, I can confirm that if you try to turn off sounds in WB config it is just back on next time open it. As for the updated Encoded skin, it has a WB5 and WB4 skin, if you have sounds you must be running the WB4 skin. WB5 skins can't use button sounds, another thing that has something to do with the per pixel frames, like also can't add extra buttons, roll up, trans window etc.
