ckythew ckythew
Problems With UI and Sound - UI Black and No Active Devices
Yes I read the thread at the top, but my problem is a little different.
I have a purchased copy of windows blinds. And yesterday my program went stupid and the UI started to go black, and I would have to reset it back every time I started my computer. It's a paint in the but
Let me remind you I DO have a purchased copy
I noticed another thing yesterday to, when I went to change my volume...the audio mixer...I get an error saying "No Active Mixer Devices Available" I didn't think these two were related, but I can't hear sound when i'm on myspace or watching youtube..ect...my Itunes sound still works however
I did however find out the two were related. When I start up my computer, I can open my audio mixer no problem adjust olume, hear sound on youtube, myspace ect. But then when my UI turns black, I get the "No Active Mixer" error
So I uninstalled it because It was pissing me off so much
but the freakin thing is still doing it, my UI is crashing, from the standard XP blue to the gray block one via Windows 98...and my sound is still giving me the same problems.
There is no doubt these things are related and windows blinds is the reason for them, but I don't understand why I still get this problem even after unintalling it.
Windows XP
Using the current Windows Blinds Version
Dell Dimension 8300
Sound Blaster Live!
Ati Radeon
please help, i really don't want to reformat my computer
8,466 views 67 replies
i'm afraid to restart my computer again, who knows what will happen
can you delete them?
do you have a registry cleaner? CCleaner will clean some out (and will make a back up copy just in case) - it's free
I, Troll.
Not, iTroll.
i rebooted and was able to delete them
then rebooted again
and the same stuff keeps happening
So there is no WB installed at all?
Did you install any other customization software?
nope, no other custom software at all...i don't know what this could be
i ran virus scans and spyware scans too...i did everything i could think of
it there anything in the event viewer?
what would I be looking for in the event viewer?
anything related to explorer or the taskbar crashing
there is a ton of application errors
well crap
maybe by scrolling down and starting where they first started you might be able to figure out what starting causing it.
me, i'd seriously consider starting backup copies with a reformat in mind
sorry, I got nothing.
maybe Yrag will stop by later.. he's full of info
What do they say??????
he's full of info
.....didn't have my glasses on.....thought that said somethin' else......
If you have uninstalled WB and you are still having problems then it is likely WB is not to blame for your problems and WB breaking is a symptom of some other problem in the same way the Active Mixer error message is.
I would look in taskmanager for an application using a lot of system resources (you will have to turn on showing GDI & USER resources when on the processes tab)
Bichur: The standalone WB installer files are not quite identical to the SDC installer.
it seems like it was the problem though, because I began to have problems similar to the post at the very top of this forum. The UI would turn black and the painting would be slow
but this really shouldn't happen with a purrchased copy, and I DO have a purchaed copy
here is what my event viewer has
The icons in your event viewer toolbar are customized.
Did you use any XPize pack? Those XP-ization packs change system files and you will NEED to revert the changes just in case it changed something important.
Reply #42 Top
I had xprize but got rid of it about a year ago because I didn't really need it
You are not suffering from the problems caused by a cracked copy.  For a start that can only impact WB 5.0 and not later versions and only when a crack has been installed.
The WB skin turning black is a symptom, not the cause of your problem.  The fact that you continue to have problems after removing WB shows this.
Reply #44 Top
ok then, thanks for replying
know of any possible reasons why this would be happening
When my explorer started all it's crashing and what not, I think it was related to trying to update Norton 2003 to 2005 previously (5 days install/uninstall = never took - broke my BITS - didn't find out for months my windows updates had failed (yeah, Yrag... I know.. updates not the only thing failed   ) - had to download SP2 on dialup (33+ hrs) - couple of months later, started getting the crashes - was in the process of making backups - was doing click, shift click to highligh skins then get properties to get size when my mouse double clicked and well over 60 WB skins tried to apply at once.
have you looked back at the beginnings of the event viewer to see approx when it started and with what?
i have but all of this means nothing to me, I mean i know how to use a computer, but when problems like this arise, i am clueless
Reply #47 Top
I am not alone !!
sorry, forgot myself.
did you try opening task mangager (ctrl+alt+del usually), then
click the processes tab
then click 'view' - 'select columns' and put a check mark in 'user object' & 'gdi objects' (i think that's what Neil mentions in #38)
then click on the 'name' "user object" or "gdi object" and the column will line up from high use to low use or vice versa {clicking it is a toggle, if the first click shows all 0s then click again)
Reply #48 Top
done ok System Idle Proicess is 99
and taskmanager, iepxplore, csrss.exe tptate frp, 01 to 00
the rest are 00
Let's try this again..... open the errors and read what the errors say. They should all be duplicates, so you only need one under the same error heading to tell you what the others are .
Namely: Userenv, Application Error and Perfnet. Also open MsInstaller and see what it tried to install.
Reply #50 Top
alright i think I may have found something
i was viewing my system process, roughly guessing what time my sound gets all screwed...by constantly opening the program until i get an error
about the time is a process called dumprep.exe and did some google research and came across this
http://spam.weblogsinc.com/2005/03/18/dumprep-exe-discoveries-is-it-spyware/
that might be the cause of my sound
as for my UI crashing..what it does now is crash then go back to normal, so fast that it is really hard for me to tell in the process window what is causing it
