Does anyone have a fix for my sound problem for gal civ 1.2?
I know it has most likely been solved. Can anyone get the static sound off every time I run 1.2?
~SDC~
342 views 3 replies
I am having the same problem! Hang in there! I would post your problem on the specific bug report for the version you are playing.
The problem started for me with 1.19 and was constant. Then it became an occasional problem with v1.20. I am hoping that it will be fixed by v1.21.
Try looking at the "If you are having sound problems, look here" post by CariElf. It's a sticky post, so you should see it near the top of the forum.
I found that if you turn on background loading and wait like 3-4 minutes before you ether load a game or start a new game it loads pretty fast and the sound doesn't clip or turn off
