when using an external monitor to extend desktop, sorting icons does not work right, they stack on top of each other. [bug?]
When I have an external monitor connected to my laptop, if I use the sort functionality, for example, sort by modified, all the icons stack on top of each other.
Here is an example:
Win10 Version 1803 (OS Build 17134.407)
Fences 3.0.9.11
6,529 views 6 replies
1) Laptop screen resolution and scaling applied.
2) External monitor resolution and scaling applied.
3) How your "Layout auto-adjustments" setting look like.
Hi, here are the answers:
1920x1080 - 100%
1920x1080 - 100%
Note the external laptop is marked as my primary monitor (where the start bar is)
Preserve my desktop layout by scaling my Fences
Hello
Would you Please try this PURGE: https://forums.stardock.com/486084/fences-support-faq#reinstalling
Reboot and report back here , please .
Also, is there a reason you are keeping Windows on and old version?
Quoting LordHadesfury, reply 5
I have the same problem on this version
 am also using fence 3
End of LordHadesfury's quote
Sorry to hear you have issues. Have you try solution suggested in reply3? Try it and let us know .
