Need help with small but annoying problem
I'm not exactly certain how - although I assume I'm accidentally hitting some kind of hotkey - but I keep toggling the time indicator to display "turns" instead of the default year-month-week setting, which is what I prefer. Exactly is the keyboard shortcut for this, and is there a way to change it to something I won't do by mistake?
8,800 views 1 replies
I don't have the best answer right now, as I don't know the hotkey that would do what you want. However, you can switch between the date and turns by clicking the display that shows this. It might not prevent you from accidentally changing the display in question (however you accidentally do it), but it would allow you to fix it.
I'll do some looking to see if you can control this by hotkey.
