Modern mix Background Sound does not work
I am using Modern Mix 1.05, which should support background sound at the netflix app. But it does not work. Every time i switch to another window, the sound stops.
// i should have looked into the options menu, it is working ;)
2,519 views 8 replies
Can someone explain this new feature? And which Netflix app is it?
Adds background sound support for apps which do not explicitly support it (like Netflix).
Quoting dypsis, reply 1
End of dypsis's quote
The feature is on the advanced page as a global on/off switch and on the app settings page on the per app right click menus to force it on/off on a per app basis.
Basically some apps like Netflix were designed to mute their audio when not the foreground app which was annoying if you ran them in a window.  This feature stops that happening.
Going forward we may default it to on for some well known apps.
Thanks for the answer, Neil.
edit: (issue solved)
Using Mixxx desktop and Sound Pad App windowed simultaniously works with beta 1.05
There is a big problem with Mixxx (1.11.0 beta2, DJing-Software from mixxx.org) and ModernMix (1.05, maybe earlier):
The GUI of Mixxx becomes unusable, as long as ModernMix is running! Some way MM seems to interfere with the Mixxx GUI and/or skinning system.
Quoting andreasgiesen, reply 5
End of andreasgiesen's quote
Can you post screenshots?
Right now I can't be sure that it is not due to a filesystem-problem I am having and only a time-conincidence... After (hopefully) recovering my Win8 -machiene I'll check again and come back to you...
Whatever caused it, I will not be able to find out anymore. I had a HDD-Crash, seems the HDD had a faulty controller, could retrieve data with special tool but have now a newly installed system on SSD... Everything works so far, Start8 and ModernMix nicely, some customizing-experiments I will not repeat.
