Weird problem with objectbar,please help
I am haveing a weird problem with objectbar that just started happening today.On the toolbar,the icons near the clock ,some of them are not showing up now. When i unload the objectbar the icons are back.When i reload the objectbar the same icons are missing.Some stay,others dont.I tried reinstalling,but same problem. Any suggestions or is this just a bug in the beta? I also tried expanding the bar with my cursor,but the same icons are missing.Also sometimes the date shows up on the single bar,other times it dont,but when i expand the bar its there. Any suggestions?
3,755 views 6 replies
if it's an xp theme, there should be an expansion arrow to show all the icons. some will be hidden due to time filtering.
if this doesn't apply, be sure you restart after installing so the new trayserver can start up and be ready to catch the icons for display in ob. if that doesn't help, run closetrayserver.exe then re-install ob, then restart.
ok,ran the closetrayserver exe and now objectbar is showing all my icons except for one,AOL., maybe its trying to tell me something? Anyways thanks for the fix migellito, will try again later to get my aol icon back onto the object bar,for some reason it dont like it..haha! Silverado,i do have .75, so it still must be a small bug in the beta.
