GoldenEagle777 GoldenEagle777
Way to imrpove Advent eco? -> neutral asteroids default to Advent when inside their culture
A lot of people talk about how much the advent eco sucks relative to the others...how about this as a way to make it better:
Neutral asteroids auto default to Advent control without needing a colony ship when they are inside of Advent culture.  Also, enemy races are not allowed to take them back so long as the culture is there.
If Advent culture overcomes an ally controlled neutral asteroid, it doesn't change hands, but enemy races are no longer able to take it so long as the culture is there.
This would make advent culture very powerful and much more advantageous and probably result in Advent players often choosing to rush culture, which is supposed to be the Advents thing.
Thoughts?
33,015 views 28 replies
Quoting DirtySanchezz, reply 22
That idea sounds overpowered.  There are better ways to help the Advent.  Return the Progenitor colonization bonus back to 20-40-60%.  Now that Illuminators have been fixed (effectively nerfed), lower the military lab requirement down to two.  That should go a long way towards helping the Advent become more competitive with Vasari and TEC.
End of DirtySanchezz's quote
The change to the Prog probably should be done independently of other decisions, if nothing else to put it more on par with the Akkan's colonize...
I personally am not a fan of a credit decrease bonus, but it is easy to implement and the Vasari already have an equivalent, so we at least have a base line to work with (4% per level)...
In principle, Advent are supposed to have the worst economy, which in theory should be compensated by a superior military...no one is going to like this change, but if illuminators only had frontal firepower and that firepower was comparable to LRMs, no one would be complaining about Advent until late-game faceoffs against fully upgraded PMs...
Quoting RiddleKing, reply 24
Halcyons (bombers) and Defense vessels are still strong enough to repel invaders before tier 3.. I think they should give defense vessel some kind of ability like the Vasari sentinel's charged missiles for a more abusive advent at tier 2.
End of RiddleKing's quote
IIRC, the sentinel's ability only affects SC...the in-game text may say otherwise but the actual ability is different from the kanraks, and I think the sentinel's deals damage to SC each use or something like that...
One could make a "synergy" ability similar to that on the beam defense platforms, and give it to defense vessels...that might work though defense vessels already are pretty damn good...I really don't favor making defense vessels OP just to compensate for an UP ship (the illuminator)...I'd rather take the direct approach and fix the illuminator which is the source of Advent's weakness...
Alternatively, making LRFs comparable to LFs in their ability to kill caps/SBs would also solve the problem (and arguably another more general problem), but there would be some inadvertent consequences of that....changing the damage tables doesn't always work out the way you'd think...
What needs to be changed is to change resource focus to passive ability of trade port like DS mod has done. That helps advent tremendously and would do long way to balance factions.
I dont think Iluminator needs to be moved to tier 2. That would make advent OP. Advent tier 0 spamm is already formidable especially against vasari with no neutrals. You don't need to move and give them counter to only counter option vasari has (skirmishers with reintegration) to tier 2.
Quoting Greg30007, reply 27
End of Greg30007's quote
Agreed. People just don't see the advents strength.
