DesConnor DesConnor
Four Capital Ship Abilities that Need Help and the Problem of Balancing With Ultimates
The Skirantra could be an Awful Warning for improvements to capital ship abilities, and unless the buff to Scramble Bombers is simply reverted with the sync fix, we will simply have the Illuminator bug issue all over again, with months with a severe balance problem. How to avoid a recurrence of this issue when recommending ability alterations?  The Skirantra was already a powerful and much used ship- it could kite, it has antimatter-free strikecraft which is like a fifth and passive capital ship ability, it has area heal including strikecraft.  Also Scramble Bombers was made vastly more powerful, if the Sova were suddenly to produce twice the number of Missile Battteries at each use at L2 and three times at L3, that still wouldn't be the equivalent of the buff to Scramble Bombers- so perhaps we could try to avoid doubling or tripling the effect of abilities...
Shield Restore The Dunov is a very rarely seen ship in Multiplayer, I've seen more Marauders, so improvements to the Dunov might not cause much pain.  Shield Restore heals one ship's shields 250/500/750 and has even been nerfed!  It can't heal the Dunov itself and as the Dunov is always the first target, so you really need two Dunovs to use the ability- the Advent Colony ship and Skirantra are best used in pairs, but their heals 300/400/500 (can heal Guardians!) and 200/250/300 (completely heals strikecraft!  Who needs Zombie Bombers?) are to an infinite number of ships within the area.
The only direct equivalent is the Kortul's Surge which affects a single ship.. 500/875/1300 heal, plus considerable speed and weapons boost.   So the Kortul single ship heal is twice as good, plus speed and weapons boost, plus it can heal itself?  And yet the Dunov is meant to be a support ship, and so carries less weapons, armour and health..?  Why was Shield Restore ever nerfed?
Of course, the great problem for TEC is the Marza problem, where at Level 6 all their abilities are suddenly extremely good.  Flux Field makes all abilities except ultimates three times as cheap, so if you can get a Dunov to level 6, and stop it being destroyed, you then can win a game you must have been winning already.  Using ultimates for faction balance is just wrong.  As it is TEC have the Sova and Akkan, which haven't a problem with rapid-use heavy antimatter abilities, and the Marza, which has a superpower at level 6- if you want to gamble on getting a single cap to level 6.  To make the Dunov work you have to get the Dunov to level 6 plus have several more caps, not an option for normal games.  TEC have problems with both early caps and late game play... not a good combination.
Animosity This ability does nothing at any of its levels, except against the AI.   It might at least be made an interrupt, though the Radiance already has one.  There have been proposals to make this ability more complex with penalties for attacking other targets, but what the Radiance really needs is an area anti-strikecraft power.  What amused me was that another of the Dunov's dubious abilities, Magnetize, could be used defensively by the Radiance, to force 8/12/16 strikecraft to 'rage quit' by crashing into the Radiance at the cost of damage.. useful if another ship is being attacked, or at lower level where small numbers of bombers and kiting can be a problem?  More strikecraft being affected might help, but at least they would be destroyed, unlike the infamous TEC Flak Burst, which too often achieves nothing at all.
Subversion  The Marauder is a better ship than it was, but suffers somewhat from the Level 6 faction problem, and its easy to destroy before Overseers turn up.  However Subversion is still rubbish.   The cost of 100 is vast, the ability does nothing.  To function, there has to be either a constructor building something, or a ship factory at the enemy planet, and both are huge priorities for destruction, rather than a temporary 50% slowdown.  On a successful raid into a back area with nothing being built, Subversion has no value at all.   An economic penalty to the affected planet might help?
Gauss Rail Gun Jam Weapons and Microphasing Aura seemed possibles, but the Kortul and Skirantra are very good and supreme capital ships respectively, with poor third abilities.  The Kol is currently dependent on the creation and survival of a L6 Dunov to make it work.. all its abilities are expensive and it has no passive, unlike the other battleships.  The Radiance equivalent of the Gauss Rail Gun does twice the damage and is an interrupt plus disable!  The Kortul gets passive interrupts..  I'd consider making either Adaptive Forcefield a passive (why does the antimatter cost increase with level on this ability, it only works when heavy damage is being taken?), or Gauss Rail Gun a passive ability, with a longer cooldown.  That would retain the utopian 'effect' of Flux Field on the other abilities but make the Kol a more viable ship in the interim.
Another set of four, there we are, I know everyone has their own opinions on capital ship abilities- but what these threads should perhaps focus on is whether there are better candidates for the four game elements most in need of help, rather than a general survey of the question.  What are the worst current elements of the game?  Otherwise we get the Skirantra problem, fixes to stuff that wasn't broken.
190,125 views 71 replies
The problem insn't that there is any ability that isn't good.  Its that in a fleet, there is no place for a Kol.  FB is too small, AF only affects the Kol, FH only affects the kol, and GRG sucks.  People use Vulks because they are awesome planet bombers despite being sucky in combat.  People use Kortuls because they void the first few SC passes and give you the advantage.  People use Progenitors because they heal your fleet.
It comes down to how well a ship supports your fleet.  The Kol does not.  It needs something, anything that gives it the ability to work as a team player rather than an indestructible brick that just sits there until everything else is dead.  I have suggested in my thread that it reduce mitigation as it gives the Kol a job in a fleet which means that people might actually build it.
I totally support buffing caps, as I've said before.  However, as counter to conventional wisdom as this may sound, I think caps currently go down far too easily to FF to be able to fulfill their role of supporting the fleet.  As such, I just build the first one these days (a colonizer), and just keep it out of all battles.  Yes, even though multiple carrier caps are all the rage, that's what I do.
Since people are so fanatical about focusing and killing caps, I wonder if something like the brick might not be a little more useful than it seems?  Get The Brick, give it the shield ability, and let the other player pound on it while you hit his frigs?  Maybe even better if you back it with a Dunov, and/or hoshis?
You might say "well what idiot would sit there and focus a Kol?"  My answer, based on my experience with online play and people's mindless single-minded dedication to focusing and killing caps, is "plenty."  Thing is though, after a certain amount of fleet has been built up, either in lrf or bombers, even the brick will go down ridiculously fast, so this strat might not be so viable, but its something to think about.  Could also try it with the Kortul, as that's a tough ship.
I actually tried it once when I lost my Sova to big a chunk of LRM's.  The brick survived a little longer, but its lifespan was still around 30-40 seconds.
The Radiance has to have an ability dedicated to getting players to focus it, so it might be more difficult to get players to focus a Kol.  The battleships seem slightly low on health and armour for their fleet role though- I suspect that they get larger increases than the other caps?  The Kortul is good fairly quickly, it's not often valuable to focus a Kortul.  I suppose with an Advent fleet you just want the best multiplier in order to wear the Guardians down.
I had hoped that the sync bug fix would also revert the Skirantra buff.  Scramble Bombers v1.19 seems absurdly powerful compered to the Halcyon level 6 ability Anima Tempest, where you get the equivalent of of 7-8 squadrons for 75 seconds?   You could have 9 bomber squadrons up with the third level of Scramble Bombers, with a duration ranging from 50s to 120s... how is that balanced?  The antimatter cost is the same, and Anima Tempest has a cooldown of 180s, whereas in another 35s the Skirantra can add another 3 bombers... I might add a revert of Scramble Bombers to the original four abilities mentioned, along with Guidance.
Weren't both Volatile Nanites and Cleansing Brilliance nerfed at some point?  They used to be the battleship answer to frigate hordes, it might be useful to have the original abilities restored?  I still prefer to have the Railgun on the Kol as the passive ability, as its the one that needs adjustment in any case.
I don't recall a nerf to either, though the nerf to Malice greatly influenced the value of CB.  With such a nerf, no longer could entire fleets be destroyed by a synergy.  Now, you have to get lucky.  Really, really, really freaking lucky...
Thanks (that's what I figured).  Now I don't have to bother trying it myself.
This isn't a comment on the skirantra either way, just a general comment on the devs and balancing.  They are just damn, damn slow with it.  Let's just assume for a minute just for the sake of argument that the skirantra scramble bombers does need a little nerf (not saying it does or doesn't).  In this case, I knew the adjustment wouldn't be coming this patch.  The question is... why?
Why does it take them years to balance this game?  Why does it take them months to tweak a stat on a ship that obviously needs it (not speaking of skirantra specifically, just any ship in general)?  One might say "because they have to rewrite code and test it, blah blah."  But they don't.  All they have to do is open a text file and change a number or two.  One might say "because balance changes are more difficult than you think - changes propagate throughout the game and have unintended effects that one might not foresee - this all requires months of deep thought, testing, etc."  Sure, sometimes.  But in the case of the skirantra (again, ASSUMING there needs to be an adjustment), this doesn't apply.  We already know what the state of the skirantra was before buff.  We know what it is after buff.  We know what the state of the game would be if we reverted.  Finally, we can also conclude that putting the skirantra somewhere between where it is now and where it was before certainly couldn't BREAK the game.  At worst, it still isn't in the sweet spot, at best it is, and on average one might think it would at least be better than what it is now.  How much testing would this take.. a couple games?   Okay, maybe a dozen at worst case?  They really lack the time to throw a couple devs together for a day and play test it?  Then open a file and change a number or two?
How long have other adjustments taken?  How long did carrier cruisers remain ridiculously OP?  How long did the illum remain ridiculously OP (yes, because of a bug, but this wasn't a difficult, elusive sync bug, it was something they discovered the source of rather quickly because they made a post about it).  How long were lrm ridiculously OP (and in my humble opinion they are STILL OP, just not as ridiculous as in earlier patches)?  On and on.
Okay, we know that the devs are bright enough chaps, so they aren't too stupid to do balancing.  I guess they just don't care enough or can't be bothered because they have other priorities?  I could actually understand this somewhat, and be willing to cut more slack if we were talking severe rocket science here.  But again, some balancing tweaks seem easy and obvious, yet they still take months, if not years.
To be fair, the developers have been working on new content up to the release of the second expansion, and might be still- I haven't given up on the Dimensional Cascades victory yet!  The last expansion seems to have had a difficult production process, with some elements having to be dropped and a few text-based pirate stat increases thrown in at the last minute.  AI improvements take developer time without seeming to add much to the game for primarily multiplayer gamers.  Also, the community seems to be very good at making threads that point out the shortcomings in the game, but rather less good at producing replays- or even mods- to demonstrate balance.
It might be useful if we could set up a balance group that would play to demonstrate balance difficulties.  The concept would be to have a set time every week to meet up and play a series of 1v1s, with the players exchanging roles for the second game.  Then we'd have something more solid to discuss.  It would only take about 6-8 of us to put something together, anyone up for that?
However, it is difficult to explain techs or abilities that have done nothing for ages and yet we've never had a new version of them to test.  Though balance minus the Skirantra issue has improved greatly overall, and it would be difficult to say that the players have a better sense, unless they are very much in agreement on an issue- and that tends to be over a problem rather than a solution.
Take Animosity- something needs to be done, yet what?  Darvin's suggestion keeps most of the original intention of the power, yet the concept of making friendly ships invulnerable with their weapons stil active makes me very wary.  Even Armistice makes both sides invulnerable and prevents them firing..  It's also far easier to set your own fleet around a capital than get the enemy into range.  If it was redone using this method I'd suggest that there should be a substantial defensive buff rather than invulnerability, and also a target cap of 6/12/18, or something along those lines.  Then you'd have a useful early defensive ability the was commensurate with Armistice and had a situational application later on.
But with the Skirantra buff reverted and work on the worst of the issues, the ones these threads are supposed to highlight, then we should end up with a very good game, one we can play for years yet.  I just hope that Trinity gets more players interested.
Put me down.  Due to a recent move, I don't have the greatest connection in the world at the moment, but that will change within the next 2 months.  I can still playtest now though, I just might be laggy.
Though balance minus the Skirantra issue has improved greatly overall...
I agree with this.  My impression is that balance has improved greatly since the inception of the game, and continues to.  I give the devs credit for this, and credit for supporting the game far in excess of what other gaming companies would have done.
All that Darvin's suggestion does is actually implement the intention of what animosity is supposed to do (make you target the Radiance), it just doesn't actually force you to target it.  You could run away, for instance, or do something else.  It would need some slight tweaks... for instance you wouldn't want the other ships in the bubble around the Radiance invulnerable to, say, a Kostura strike, or mines that had been laid.  You wouldn't want them invulnerable to Subverter strikes either, it seems.  You wouldn't want them invulnerable to ships that were firing from outside the range of the bubble, if that's possible, and you wouldn't want it to affect Ogrovs or Adjudici (which aren't even allowed to target ships).  Other than that, though, I would support Darvin's idea as something that implements what the dev's intention seems to have been.  I also like my idea - just dump a certain portion of the damage being taken from all ships in a radius around the Radiance onto the Radiance.
Now, an entirely different issue is... do you think that the original intention of the devs with this ability is flawed from the get-go?  In other words, if the Radiance actually forced you to target it (as it does against the AI), without you being able to retarget, it would be broken, OP, etc?  Is that what you (and possibly lbgsloan) are saying?  I haven't examined that issue, but it might be possible.  My issue has just been that the ability doesn't do anything at all against a human opponent.
Yeah the damage transfer concept seems much like the defensive buff to the fleet in the area of effect, rather than the problematic invulnerability.  I'm just not sure of the rationale for the damage transfer though?  The extra defensive buff you could justify as the hindrance of rage.  Something like 15% up to 35% at level 3 for 20s might be enough incentive to retarget, and is a significant boost?  The cooldown might need increasing though.  The concept of Animosity is okay I reckon, its just the implementation that could get messy.
So what time could you make, if we have to agree a regular time to test?  Also anyone else who wants to join in should add what times they are available too.  Some considerable experience with the game has to be a requirement, unfortunately- we could match less familiar players with each other but I'm not sure what could be learned.
If you are asking for a lore-based rationale, I have none.  I have never cared for lore when it comes to balancing any game.  I suspect that a sufficient lore could quite easily be constructed, as Volt saw when I proposed another solution to something months ago.  But for me personally, this is unimportant.
But if you are asking the rationale for why the ability should dump damage to the Radiance (the rationale for how this would implement the currently unimplemented "Animosity"), that's easy.  The original intent (which doesn't work) is to have 100% of the damage done to the fleet redirected to the Radiance.  My altered version does this - it directs the damage done to the fleet onto the Radiance.  The percentages?  Completely debatable.  100% would work exactly like Animosity is supposed to work now.  Less would work somewhat differently.
I could see at least 3 different ways to approach this.  One would be to have the ability level up based on percent of damage redirected to the Radiance (33%/50%/66% or whatever).  Another would be to have the ability redirect 100% of the damage, but level up based on time (4/6/8 seconds or whatever).  Yet another would be to mix both percent of damage redirected, and time.
One criticism of this approach was that this functions "too much" like the shield guardian ability.  Not that I care, but for those who do, my reply is that this would also direct damage to the hull of the Radiance when shields are gone - something that doesn't occur (to my knowledge) with shield guardians.  I would also say that this being similar to the shield guardian ability also means it would be easy for the devs to implement - they already have the existing functionality in the code (largely).  Finally, I would say that the similarity of it functioning like the shield guardian is really just a matter of perspective (its all in your mind).  What it really functions like is the intent of animosity.
As far as arranging time to work on balance issues, just PM me when you need help and we will arrange something.
EDIT:  It would also be possible to have both my ability, and Darvin's ability, be channeling, therefore interruptable.  This would probably be more desirable in the case of Darvin's suggestion since people worry about it being an "I win button."  This would also give someone reason to build an interupt-dealing capship to counter.
Animosity no matter what you do in way of disabling ships can be more op than 1 subverter.1 sub can disable an entire fleet from shooting and moving.Add vas ability to deploy mines anywhere and you can destroy hundreds of ships with about 15-20 ships.So how is a cap ability going to overshadow this?
With the current implementation of Animosity, what happens to the left and right banks of weapons of affected ships- are they silenced, or are they free to fire at other targets?  I'm still not happy with the concept of invincibility for the accompanying fleet, unless there was some method of restricting it so that it applied only to enemy ships within the area of effect.  Damage transfer seems to remove all the synergy of Animosity with other abilities, as well as allowing a much better damage multiplier for fire on a cap?  A defensive buff for surrounding ships, rather than invulnerability, might avoid these issues?
The weekend is approaching- anyone else want to help form a group to test play balance?  We'd need about 6-8 at least.
As much as I'd love to help, I don't ever play online, so sorry there.  Still and all, I wish to try a few comp stomps with friends before actually playing online.  Right now, I'm trying to convince my girlfriend to try the game and then will proceed to attempt to get a couple of my friends in on it.  Ah the wonders of being a nerd and being surrounded by others...
Reply #39 Top
One of my objections to the Skirantra buff as well as any proposed Egg colony buff is that up to v1.18 the Vasari had the most balanced set of capitals in the game, good battleships and siege as well as one situational capital ship that still had a few problems but which had been improved.  It was the other factions that had problems with variety.  The Marauder is the only Vasari capital I'd alter further, after a revert of the Skirantra buff.
Though many players select the Kol as the worst capital in the current version of the game, there are other outstanding contenders.  After all the problem with the Kol is that its antimatter usage is prohibitive, not that the abilities themselves are poor.
The Radiance is another battleship that doesn't function in the current version.  The Kol has more chance with Assailants and strikecraft, all that the Radiance has is its passive armour, the antimatter drain isn't effective against frigates.
The Revelation would be my choice for worst capital.  Before level 6 both the Marza and Vulkoras are effective siege capitals with a secondary ability that can strike several smaller ships at once.  Whatever you make of phase missile swarm- and it is disfavoured compared with radiation bomb, as well as being peculiarly named, why not just let it shoot phase missiles then?- it will damage enemy frigates in combat.  The Revelation lacks any ability to deal extra damage to attacking light frigates.  Guidance just uses up antimatter faster on other capital ships if you have any (are there stacking problems with some abilities?) and Clairvoyance isn't much use after battle begins.  Also, the Revelation is considerably less durable than either of the other siege capitals, it ties with the Antorak as being the weakest capital in the game, without the Antoraks speed to get it out of trouble, and heavy on shields to make it even more vulnerable to phase missiles.
However the worst feature of the Revelation is that it just doesn't fulfil its primary role.  It has no extra siege ability until level 6- and even then the ultimate isn't especially useful against asteroids, volcanics and ice planets where the population is low.  This means that Advent players can justify their endless stream of colony capitals and Halcyons on the basis that they need more capital ships, because they effectively have no siege capital.
To repeat my take on capital ship rankings currently (overall):
  1. Skirantra
  2. Halcyon
  3. Progenitor
  4. Sova
  5. Akkan
  6. Kortul
  7. Jarrasul
  8. Marza
  9. Radiance
  10. Vulkoras
  11. Rapture
  12. Kol
  13. Revelation
  14. Dunov
  15. Antorak
I'd put Kol at 12th overall, which is pretty near the bottom.  I'd say Revelation, Dunov, and Antorak are worse.  They certainly all need help to be competitive.  In any case, we need to look at both the holistic capital ship (how it performs both in general and in a specific role) and its individual abilities, that they all have their strong points.  For the most part, the higher level capital ships on my list don't need to be touched, and maybe only need one ability tweaked (I'm still looking for a Jarrasul colonize buff).  The lower ones need to be really boosted dramatically to be made useful.
I would have put the Marza ahead of the Jarrasul, but at any rate, that is pretty much what I think as well.
Reply #42 Top
I think the egg's superior attacking capabilities (nano-dissassem) can justify it not being an economic-powerhouse like akkan or mothership.  But I'd certainly buff the build rate buff on its colonization - the current numbers on it are ridiculous.  But either rate, adjustments to this cap should take an extreme low priority.
Yeah, the reason for this is the use of the Kostura as a delivery method to take your ships deep into enemy territory.  For this reason, it needs something.  Perhaps have the build rate increase by 33%/67%/100% and/or add 1/2/3 extra constructors (isn't this how the ability was originally?)
Reply #44 Top
Of course, what would be ideal would be if the Egg's colonisation bonus could vary depending on the number of neutral extractors on the map.  Does the build rate increase apply to starbases?
Even with the sort of level of build rate increase suggested, won't the economic advantages be almost nil, so that the only real effect is if you want defences where you've just colonised?  It still won't provide a real boost in the early game, should Vasari need one because of an absence of extractors?
The sort of boost it might need would be one where it is very slight at level one, but good at level two and three if you want to, or have to, go the colony path.  However a buff to the existing ability is perhaps helping turret and repair construction far more than finances?
It's good that the Marauder has fans, but Subversion doesn't and I see no reason to remove it from the list of the worst abilities.  This is another aspect of the Scramble Bombers fiasco, where if an ability is routinely the second chosen, then it is the third ability that needs boosting, if any.
That the Radiance is already the highest ship on the list to profit from abilities that need boosting makes me want to be even more cautious about the temporary invulnerability for friendlies concept.  I'd much prefer a temporary defensive buff if the ability were to be redeseigned to work on friendlies... thats certainly not how it was originally designed, and not having to 'catch' enemies in the area of effect is removing the skill originally required for use.
How about a general penalty to enemy ships caught in the area of effect, but also a general bonus for firing on the Radiance..?   Of course the Radiance might have to leave quickly if there are a few ships arriving late to the action.. sounds fun?
With Guidance, how about a small buff to antimatter restore rates as well?
Quoting DesConnor, reply 44
End of DesConnor's quote
That's what I proposed, as well - check my post here, if you're interested.
But the point is that I'm not asking for it to become the premiere economic powerhouse, I'm asking for it to have some economic utility.  Beyond that, I don't really agree with you in the first place.  While it's not much for a one on one capital ship fight, the Progenitor is awesome fleet support.  Secondly, when it comes to sheer early game muscle, the egg's glory days ended with version 1.18.  The carrier capital ships now rule the roost, and the days of a dominant egg are over.  This time last year you could easily have pulled this argument to say that the egg's colonize ability should be left as is, but today it just doesn't hold water.  The egg is maybe 4th or 5th (after all three carrier capital ships and perhaps the Kortul) in terms of its rank for sheer combat power.
In other words, the egg is no longer a combat powerhouse.  Get over it, the glory days of the egg are over and it's time to buff it up for what it is:  a colony capital ship.
No, much as the Sova's rapid manufacturing ability does not apply.
Maybe it's a pipe dream, but I'm still hoping to see repulsion put on the Revelation and the Guardian to get a modified version of guidance...
Reply #47 Top
I suspect that Warlord Mike's concept is more likely.   You can't be sued for repeating someone else's suggestion if its adopted in a game, can you?
The problem with the Egg is as much about the initial Vasari advantage with neutral extractors as about sheer combat power, though buffing the 4th/5th best combat ship would be worrying by itself....  If there's a flak buff it'll affect the dominance of the carrier capitals- as will the longed for revert of Scramble Bombers.  Buff the worst capitals first, and lets also see if we can get away from the lurching between LRF and strikecraft superiority that has hampered the game to date.
Reply #48 Top
Point taken.  I'm convinced.
The Egg's ability seems to be more aimed at the fast construction of defences than financial expansion.  Vasari have an advantage over neutral extractors anyway.  I would find it very difficult to justify improvements to the Egg.  As well as nano, the other two abilities are extremely good in the later game- what rank is the Egg in terms of sheer siege power?  Not a priority.
There's been some very dubious discussion of the Skirantra and Scramble Bombers on other threads.  The buff to the first level of Scramble Bombers was very slight, so I can't understand why anyone would want to discuss low-level Skirantras at all, there's scarcely any difference.  The real problem is that at the third level the ability is from 50% to 100% more powerful than the Halcyon's very similar ultimate ability.  The developers seemed to buff the Halcyon's ultimate in v1.18, with no other reason than to keep pace with the Skirantra, then entirely abandoned this very justifiable practice for v1.19.... and I'm not claimining that the Halcyon's ultimate needs a further buff!
I suppose that the point for this thread is that perhaps suggested amendments to abilities should be related to other similar existing abilities- like Animosity becoming a version of Armistice, or comparing any adjustment to Gauss Rail Gun to other direct damage abilities like nano, Radiation Bomb and Disintegration.  This might avoid the Scramble Bombers issue in future.
Reply #50 Top
Quoting DesConnor, reply 47
Nope, sure can't.  And it makes sense, doesn't it Des?
Considering how quickly the pendulum seems to swing around here, this may well be the best thing we can do at this point - ignore abilities that people are going "OMGNERFPLZ" at the moment, and worry about the crappier ones right now (it's even in the topic's title, for godsakes!) before we get to the other ones.
