Pacov/Kalel's QA testing for Sorian's current DG mods - boots of better speed and the fire TB fix - see for results
I ran several test scenarios with Kalel's assistance to better understand how the modding system works and used 2 of Sorians mods for these tests...boots of better speed
The boots of better speed mod can be found here: http://sorian-ai-mod.googlecode.com/files/Boots%20of%20better%20speed.zip as discussed here: http://forums.demigodthegame.com/369563
The fire tb fix mod can be found here:  http://sorian-ai-mod.googlecode.com/files/Fire%20TB%20Fix.zip as discussed here:  http://forums.demigodthegame.com/369610.
He just released another mod that I did not include in this test here http://forums.demigodthegame.com/369614/#2449953
Here are the test results:
All 1v1 games
TEST 1:
            Host:  pacov
            Installed mods - boots of better speed
            Enabled mods - boots of better speed
            Player:  Kalel
            Enabled mods - NONE
Outcome - both kalel and pacov can buy and use better speed.  HOST'S forced all players to be Enabled
TEST 2:
            Host:  pacov
            Player:  Kalel
            Installed mods - NONE
            Enabled mods - NONE
Outcome -kalel can't join the game.  get's message:  one or mods in use in this game are missing or out of date.  problem mods are marked with a * in the game tooltip.
TEST 3:
            Host:  pacov
            Enabled mods - NONE
            Player:  Kalel
Outcome - kalel can join the game, but no one can use the mod.
            Host:  pacov
            Enabled mods - NONE
            Player:  Kalel
Outcome - kalel can join the game, but the mod is not turned on for everyone
Fire TB Test
TEST 1:
            Host:  pacov
            Installed mods - fire tb fix
            Enabled mods - fire tb fix
            Player:  Kalel
            Enabled mods - NONE
Outcome - (pacov get's swift ank+ boots of speed... pacov's fire tb hits and attacks on the move)... tried a 2nd game with same settings, but kalel gets swift ank + boots of speed - kalel's fire tb hits and attacks on the move)
TEST 2:
            Host:  pacov
            Player:  Kalel
            Enabled mods - NONE
Outcome -kalel can't join the game.  get's message:  one or more mods are in use in this game are missing or out of date.  problem mods are marked with a * in the game tooltip.
3,253 views 15 replies
NT
test 3 of the boots test. kalel could actually get the boots and use them???
Quoting Derog, reply 2
End of Derog's quote
No, only the host can enable sim-mods.
yeah... I worded that poorly... I'll update the OP.
edit - OP = fixed.
Why poorly? That's the way it should be ;).
It would be useful if maybe the name of the missing/outdated mod could be displayed.
And are the Better Boots of Speed balanced? :D
oh yes... 200% speed increase for 1000 gold.  lolz.  Fun though.
So if i replace the two files with the ones you linked above, I can play a Autoattacking Fire TB?
Quoting Piznit, reply 8
End of Piznit's quote
No, you just have to extract the archive into the bindata/mods folder of Demigod.
hmm, is there a free unzipper I should use?  Im pretty much dont know how to do any of that sort of thing
Quoting Piznit, reply 10
LOL! use any of these programms:
http://www.7-zip.org/download.html
http://download.cnet.com/WinZip/3000-2250_4-10003164.html
http://www.win-rar.com/download.html
Yeah, use 7-zip.
If you have Vista, the built-in extractor is extremely nice.
I personally use WinRar but my second favorite is 7-Zip.
Anyway use whatever suits you.
Quoting Colonel_Jessep, reply 6
End of Colonel_Jessep's quote
It is. When you hover over a game any mods that you are missing have an asterisk(*) next to them. There is even a pop-up window that tells you that if you try to join a game that is using a mod that you don't have.
