LAG problems, Sound Glitches
hi, ummm...it seems that when i bought this game (i was so excited) i thought it was gonna run smoothly, even if i had to put it on Low graphics and everything. The Specs even say that i could play it.
I dnt kno if its my computer, but the game lags sooo badly, its going about 3-5 FPS.
My CPU is a AMD Athlon(tm) 64 Processor 3200+, 2.01 GHz
I also have bout 1.75 RAM
And my Video Card is a NVIDIA GeForce 8500 GT
And if that wasnt enough.....sometimes the games sound itself would kinda lag to. I mean....u can hear it....but it kinda glitches over and over.
Please help, and THNX!!
32,201 views 8 replies
I have the exact same problem.... 3 frames a second would be great... im getting like 0.5.
Choppy, crappy sound
CPU AMD 64 X2 4200+
2 Gb ram
NVIDIA 260 gtx  896 MB.
THIS SHOULD BE ABLE TO RUN THIS GAME!
Can anyone help?
your computer is really slow; the biggest clinch-pins are you single-core CPU, and entry-level GPU. i suggest you start saving up your pennies for a new computer; shop around and building it yourself and you'll get a killer setup for under $700.
thnx for the suggestion, but wat do u mean by "entry-level GPU"
Quoting Chronos-X, reply 4
End of Chronos-X's quote
the cheap stuff that's not really expected to play games on.
it was an okay card when it came out, however that was a few years ago (and Demigod is brand-spanking-new).
The game should be fine on that GPU - won't be great but I don't think should cause the lag you are experiencing
I suspect like a lot of us the issue is a problem with the sound side of things which is causing the game to lag.
I have an AMD 3200+, 8800GT, 2GB ram. Running with the /nosound switch I get +40fps, without it I am lucky if I squeeze 20fps.
Try it and if it works then post to  http://forums.demigodthegame.com/348232
Tals
thanks alote bullet and talsworthy. Since i dnt have the BUCKS ($$$) to actually buy a computer right NOW....i'll go wit talsworthy idea.
But in bout 6 months, i should be able to either upgrade my pc, or buy a totally new one. Dnt kno which exactly, but when that time comes, i'll choose.
If any suggestions, i'm happy to hear them
I have experienced the full aspects of the Nosound Performance Issue, with framerates being slow and sound being choppy whereas I had a whole new generation Geforce Card (GTX 260), no problem with any other game on Full Details, and 4GB RAM.
I have found a solution to this issue that I haven't seen reported in the Technical Support forum. This solution has been found by some users and reported in a "Supreme Commander" forum section. The user reported a bad link though, whereas I will supply here the right link.
This is a problem linked to corrupted DirectX library.
A file (
d3dx9_36.dll
may be downloaded here :
It needs to be installed in windows/system32.
This file has same size and about same date that the original file I had there, except that the date I had was 4:04 PM and this one is 3:04 PM.
After copying & pasting this file there, I experience absolutely no issue.
Sound is smooth, game becomes smooth like hell.
Please try this if you are experiencing problems.
And report here if this works :-)
