Add-On Sound Problems, please help
Hi all!
I just bought the Add-On to Sins but I have two issues with the sound of the game which I cant fix alone.
The first is that I have some sudden "cracking" sound now and then (happens more often when there are more sound effects playing at once like in a fight for example). If this cracking occurs my game halts for a very short moment (like a part of a sec but long enough to recognize there is something wrong)
The second one is that if one sound is playing (for example when I klick a unit or building) and in THIS time a ship is build, a capital lost shield, is heavily damaged etc. where there should be a sound notification, there simply is none.
My game seems only to be able to play one of these "talkings, reports, responses" or whatever you call these sounds at once. The firing sounds in battle seems to work right and overlap each other as usual (for example when two weapons are fired short after each other).
Has someone an ideo on what that might be? I dont have much knowledge about this computer - stuff so every help is appreciated.
By the way direct x, sound and graphic drivers are updated, I even tried uninstalling the new sound driver and reinstalling the very old one which was delivered on CD with the sound card - no success :-(
Thank you in advance,
Hrothgaar
System Information
Time of this report: 2/26/2009, 16:33:42
       Machine name: STEFFENS
   Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.080814-1236)
           Language: German (Regional Setting: German)
System Manufacturer: System manufacturer
       System Model: System Product Name
               BIOS: Phoenix - AwardBIOS v6.00PG
          Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 4600+,  MMX,  3DNow (2 CPUs), ~2.4GHz
             Memory: 2046MB RAM
          Page File: 622MB used, 3316MB available
        Windows Dir: C:\WINDOWS
    DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
     DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
  DirectX Files Tab: No problems found.
      Display Tab 1: No problems found.
        Sound Tab 1: The file ctaud2k.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL).  You may be able to get a WHQL logo'd driver from the hardware manufacturer.
          Music Tab: No problems found.
          Input Tab: No problems found.
        Network Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (n/a)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
        Card name: NVIDIA GeForce 7950 GX2
     Manufacturer: NVIDIA
        Chip type: GeForce 7950 GX2
         DAC type: Integrated RAMDAC
       Device Key: Enum\PCI\VEN_10DE&DEV_0294&SUBSYS_81FB1043&REV_A1
   Display Memory: 512.0 MB
     Current Mode: 1680 x 1050 (32 bit) (60Hz)
          Monitor: Plug und Play-Monitor
  Monitor Max Res: 1600,1200
      Driver Name: nv4_disp.dll
   Driver Version: 6.14.0011.8122 (English)
      DDI Version: 9 (or higher)
Driver Attributes: Final Retail
 Driver Date/Size: 1/15/2009 08:19:00, 6168960 bytes
      WHQL Logo'd: Yes
  WHQL Date Stamp: n/a
              VDD: Nicht zutreffend
         Mini VDD: nv4_mini.sys
    Mini VDD Date: 1/15/2009 08:19:00, 6301248 bytes
Device Identifier: {D7B71E3E-41D4-11CF-496C-F0A100C2CB35}
        Vendor ID: 0x10DE
        Device ID: 0x0294
        SubSys ID: 0x81FB1043
      Revision ID: 0x00A1
      Revision ID: 0x00A1
      Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
 Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
         Registry: OK
     DDraw Status: Enabled
       D3D Status: Enabled
       AGP Status: Enabled
DDraw Test Result: Not run
 D3D7 Test Result: Not run
 D3D8 Test Result: Not run
 D3D9 Test Result: Not run
Sound Devices
            Description: SB X-Fi Audio [8C00]
 Default Sound Playback: Yes
 Default Voice Playback: Yes
            Hardware ID: PCI\VEN_1102&DEV_0005&SUBSYS_00311102&REV_00
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            Driver Name: ctaud2k.sys
         Driver Version: 6.00.0001.1368 (English)
            WHQL Logo'd: No
          Date and Size: 10/8/2008 01:21:50, 526232 bytes
            Other Files:
        Driver Provider: Creative
         HW Accel Level: Full
              Cap Flags: 0xF5F
    Min/Max Sample Rate: 1, 192000
Static/Strm HW Mix Bufs: 128, 128
 Static/Strm HW 3D Bufs: 128, 128
              HW Memory: 0
       Voice Management: Yes
 EAX(tm) 2.0 Listen/Src: Yes, Yes
   I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
               Registry: OK
      Sound Test Result: Not run
Sound Capture Devices
  Default Sound Capture: Yes
  Default Voice Capture: Yes
              Cap Flags: 0x41
           Format Flags: 0xFFF
DirectMusic
        DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
     DLS Version: 1.00.0016.0002
    Acceleration: Enabled
           Ports: SB X-Fi DMusic Synth [8C00], Hardware (Kernel Mode), Output, DLS, Internal, Default Port
                  SB X-Fi Audio [8C00], Software (Kernel Mode), Output, DLS, Internal
                  Microsoft MIDI-Mapper [Emuliert], Hardware (Not Kernel Mode), Output, No DLS, Internal
                  SB X-Fi Synth B [8C00] [Emuliert], Hardware (Not Kernel Mode), Output, No DLS, Internal
                  SB X-Fi Synth A [8C00] [Emuliert], Hardware (Not Kernel Mode), Output, No DLS, Internal
                  Microsoft GS Wavetable SW Synth [Emuliert], Hardware (Not Kernel Mode), Output, No DLS, Internal
                  Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal
        Registry: OK
DirectInput Devices
      Device Name: Maus
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Tastatur
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
      Device Name: Gaming Keyboard
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC221
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
      Device Name: G15 Keyboard
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC222
        FF Driver: n/a
      Device Name: WD HID Interface
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x1058, 0x0905
        FF Driver: n/a
Poll w/ Interrupt: No
         Registry: OK
USB Devices
+ USB-Root-Hub
| Vendor/Product ID: 0x10DE, 0x036C
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 4/13/2008 19:45:37, 59520 bytes
| Driver: usbd.sys, 2/28/2006 13:00:00, 4736 bytes
+-+ Standard-USB-Hub
| | Vendor/Product ID: 0x046D, 0xC223
| | Matching Device ID: usb\class_09
| | Service: usbhub
| +-+ USB-HID (Human Interface Device)
| | | Matching Device ID: usb\class_03
| | | Service: HidUsb
| | | Driver: hidusb.sys, 4/13/2008 19:45:27, 10368 bytes
| | | Driver: hidclass.sys, 4/13/2008 19:45:26, 36864 bytes
| | | Driver: hidparse.sys, 4/13/2008 19:45:22, 24960 bytes
| | | Driver: hid.dll, 4/14/2008 03:22:11, 20992 bytes
| | +-+ HID-konformes Gerät
| | | | Matching Device ID: hid_device
| | +-+ HID-Tastatur
| | | | Matching Device ID: hid_device_system_keyboard
| | | | Service: kbdhid
| | | | Driver: kbdhid.sys, 4/14/2008 02:58:37, 14720 bytes
| | | | Driver: kbdclass.sys, 4/14/2008 02:58:36, 25216 bytes
+-+ Microsoft IntelliMouse Explorer (USB)
| | Vendor/Product ID: 0x045E, 0x001E
| | Matching Device ID: usb\vid_045e&pid_001e
| | Service: HidUsb
| | | Matching Device ID: hid\vid_045e&pid_001e
| | | Service: mouhid
| | | Driver: mouclass.sys, 4/14/2008 02:49:36, 23552 bytes
| | | Driver: mouhid.sys, 2/28/2006 13:00:00, 12288 bytes
Gameport Devices
PS/2 Devices
+ HID-Tastatur
| Service: kbdhid
+ Terminalserver-Tastaturtreiber
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 4/14/2008 03:23:26, 40840 bytes
+ Terminalserver-Maustreiber
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 TCP/IP Service Provider: LAN-Verbindung Konsolen - IPv4 -
DirectPlay8 TCP/IP Service Provider: T-Online 6.0 - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1,4 KBit/s
Voxware SC06 6,4 KBit/s
Voxware SC03 3,2 KBit/s
MS-PCM 64 KBit/s
MS-ADPCM 32,8 KBit/s
Microsoft GSM 6.10 13 KBit/s
TrueSpeech(TM) 8,6 KBit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
      Drive: C:
 Free Space: 10.2 GB
Total Space: 25.0 GB
File System: NTFS
      Model: ST3320620AS
      Drive: D:
 Free Space: 162.1 GB
Total Space: 280.2 GB
File System: NTFS
      Model: ST3320620AS
      Drive: G:
 Free Space: 330.0 GB
Total Space: 953.9 GB
File System: NTFS
      Model: WD My Book USB Device
      Drive: E:
      Model: PLEXTOR DVD-ROM PX-130A
     Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.5512 (German), 4/13/2008 19:40:46, 62976 bytes
      Drive: F:
      Model: PLEXTOR DVDR   PX-760A
System Devices
     Name: AVM ISDN-Controller FRITZ!Card PCI v2.0
Device ID: PCI\VEN_1244&DEV_0E00&SUBSYS_0E001244&REV_01\4&1CEFD014&0&4070
   Driver: C:\WINDOWS\system32\DRIVERS\fpcibase.sys, 3.00.0000.0000 (English), 8/17/2001 12:14:24, 444416 bytes
   Driver: C:\WINDOWS\system32\fpcibase.sys, 3.00.0000.0000 (English), 8/17/2001 12:14:24, 444416 bytes
   Driver: C:\WINDOWS\SYSTEM\capi.dll, 1.05.0000.0000 (), 7/21/2001 18:37:18, 18372 bytes
   Driver: C:\WINDOWS\SYSTEM\capi20.dll, 1.05.0000.0000 (), 7/21/2001 18:37:18, 18852 bytes
   Driver: C:\WINDOWS\system32\avmcoxp.dll, 2.02.0001.0000 (German), 8/18/2001 04:53:02, 87552 bytes
   Driver: C:\WINDOWS\system32\avmenum.dll, 1.00.0000.0001 (German), 8/18/2001 04:53:02, 144384 bytes
   Driver: C:\WINDOWS\system32\capi2032.dll, 5.00.0000.0000 (German), 8/18/2001 04:53:02, 10240 bytes
     Name: Creative SB X-Fi
Device ID: PCI\VEN_1102&DEV_0005&SUBSYS_00311102&REV_00\4&1CEFD014&0&3070
   Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.5512 (German), 4/14/2008 04:22:14, 4096 bytes
   Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.5512 (German), 4/14/2008 04:23:08, 129536 bytes
   Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.5512 (German), 4/13/2008 21:16:36, 141056 bytes
   Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.5512 (English), 4/13/2008 20:45:14, 60160 bytes
   Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.5512 (English), 4/13/2008 21:19:42, 146048 bytes
   Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.5512 (German), 4/13/2008 20:45:16, 49408 bytes
   Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.5512 (English), 4/14/2008 04:23:08, 23552 bytes
   Driver: C:\WINDOWS\system32\drivers\ctac32k.sys, 6.00.0001.1361 (English), 10/8/2008 01:21:46, 511000 bytes
   Driver: C:\WINDOWS\system32\drivers\ctaud2k.sys, 6.00.0001.1368 (English), 10/8/2008 01:21:50, 526232 bytes
   Driver: C:\WINDOWS\system32\drivers\ctoss2k.sys, 6.00.0001.1368 (English), 10/8/2008 01:21:56, 130072 bytes
   Driver: C:\WINDOWS\system32\drivers\ctprxy2k.sys, 6.00.0001.1368 (English), 10/8/2008 01:21:58, 14360 bytes
   Driver: C:\WINDOWS\system32\drivers\ctsfm2k.sys, 6.00.0001.1368 (English), 10/8/2008 01:22:00, 158744 bytes
   Driver: C:\WINDOWS\system32\drivers\emupia2k.sys, 6.00.0001.1368 (English), 10/8/2008 01:22:02, 95768 bytes
   Driver: C:\WINDOWS\system32\drivers\ha20x2k.sys, 6.00.0001.1368 (English), 10/8/2008 01:22:04, 1177624 bytes
   Driver: C:\WINDOWS\system32\drivers\pfmodnt.sys, 3.00.0000.0012 (English), 10/8/2008 01:22:06, 15384 bytes
   Driver: C:\WINDOWS\system32\drivers\CTEXFIFX.sys, 6.00.0001.1368 (English), 10/8/2008 01:21:44, 1324056 bytes
   Driver: C:\WINDOWS\system32\drivers\CT20XUT.sys, 6.00.0001.1368 (English), 10/8/2008 01:21:38, 171032 bytes
   Driver: C:\WINDOWS\system32\drivers\CTHWIUT.sys, 6.00.0001.1368 (English), 10/8/2008 01:21:40, 72728 bytes
   Driver: C:\WINDOWS\system32\ctdlang.dat, 10/7/2008 23:31:14, 321512 bytes
   Driver: C:\WINDOWS\system32\ctdnlstr.dat, 10/7/2008 23:31:14, 56509 bytes
   Driver: C:\WINDOWS\system32\CtxfiRes.dll, 6.00.0001.1368 (English), 10/7/2008 23:41:40, 2560 bytes
   Driver: C:\WINDOWS\system32\ctzapxx.ini, 9/12/2008 21:22:40, 54 bytes
   Driver: C:\WINDOWS\system32\instwdm.ini, 10/8/2008 00:08:38, 20936 bytes
   Driver: C:\WINDOWS\system32\CT1MGM.ROM, 2/25/2000 12:49:34, 1048576 bytes
   Driver: C:\WINDOWS\system32\CT2MGM.SF2, 9/22/1999 23:18:38, 2167684 bytes
   Driver: C:\WINDOWS\system32\default4.sfm, 1/3/2002 15:44:16, 59 bytes
   Driver: C:\WINDOWS\system32\default8.sfm, 1/3/2002 15:44:16, 59 bytes
   Driver: C:\WINDOWS\system32\default.sfm, 1/3/2002 15:44:16, 59 bytes
   Driver: C:\WINDOWS\Temp\ctpxst32.exe, 1.01.0000.0059 (English), 3/13/2007 10:32:14, 89336 bytes
   Driver: C:\WINDOWS\Temp\cttele32.dll, 1.00.0011.0000 (English), 2/4/2008 10:27:58, 102400 bytes
   Driver: C:\WINDOWS\system32\regplib.exe, 10/7/2008 23:26:38, 16384 bytes
   Driver: C:\WINDOWS\system32\a3d.dll, 80.00.0000.0003 (English), 10/7/2008 23:42:42, 60928 bytes
   Driver: C:\WINDOWS\system32\ac3api.dll, 6.00.0001.1368 (English), 10/7/2008 23:42:16, 48640 bytes
   Driver: C:\WINDOWS\system32\eaxac3.dll, 1.01.0002.0000 (English), 7/11/2001 10:51:00, 77824 bytes
   Driver: C:\WINDOWS\system32\ctosuser.dll, 6.00.0001.1368 (English), 10/7/2008 23:26:44, 74752 bytes
   Driver: C:\WINDOWS\system32\ctemupia.dll, 6.00.0001.1368 (English), 10/7/2008 23:30:32, 114688 bytes
   Driver: C:\WINDOWS\system32\piaproxy.dll, 6.00.0001.1368 (English), 10/7/2008 23:26:36, 68608 bytes
   Driver: C:\WINDOWS\system32\ctdproxy.dll, 6.00.0001.1368 (English), 10/7/2008 23:27:26, 53248 bytes
   Driver: C:\WINDOWS\system32\devreg.dll, 6.00.0001.1368 (English), 10/7/2008 23:23:26, 36864 bytes
   Driver: C:\WINDOWS\system32\ctasio.dll, 6.00.0001.1368 (English), 10/7/2008 23:27:32, 50688 bytes
   Driver: C:\WINDOWS\system32\ct_oal.dll, 6.00.0001.1368 (English), 10/7/2008 23:27:36, 193024 bytes
   Driver: C:\WINDOWS\system32\ctpxst32.exe, 1.01.0000.0059 (English), 3/13/2007 10:32:14, 89336 bytes
   Driver: C:\WINDOWS\system32\APOIM32.exe, 2.29.0000.0000 (English), 7/18/2008 09:39:18, 595249 bytes
   Driver: C:\WINDOWS\system32\oalinst.exe, 2.00.0006.0000 (English), 4/23/2008 06:07:50, 805400 bytes
   Driver: C:\WINDOWS\system32\AddCat.exe, 0.00.0000.0001 (English), 12/5/2006 14:52:40, 48400 bytes
   Driver: C:\WINDOWS\system32\CTAPO32.UDA, 8/21/2008 15:32:36, 7954 bytes
   Driver: C:\WINDOWS\system32\CTMLFX32.UDA, 6/2/2008 11:10:04, 5458 bytes
   Driver: C:\WINDOWS\system32\AppSetup.exe, 1.00.0000.0018 (English), 9/25/2008 15:40:32, 20888640 bytes
   Driver: C:\WINDOWS\system32\CTxfiBtn.dll, 6.00.0001.1368 (English), 10/7/2008 23:41:38, 41472 bytes
   Driver: C:\WINDOWS\system32\CTxfiSpk.dll, 6.00.0001.1368 (English), 10/7/2008 23:41:38, 39424 bytes
   Driver: C:\WINDOWS\system32\Ct20xspi.dll, 6.00.0001.1368 (English), 10/7/2008 23:37:44, 15360 bytes
   Driver: C:\WINDOWS\system32\CTxfispi.exe, 6.00.0001.1368 (English), 10/7/2008 23:37:38, 1212928 bytes
   Driver: C:\WINDOWS\system32\Ctxfihlp.exe, 6.00.0001.1368 (English), 10/7/2008 23:41:36, 23552 bytes
   Driver: C:\WINDOWS\system32\CTxfiReg.exe, 6.00.0001.1368 (English), 10/7/2008 23:37:46, 47104 bytes
   Driver: C:\WINDOWS\system32\enlocstr.exe, 10/7/2008 23:23:50, 7680 bytes
   Driver: C:\WINDOWS\system32\killapps.exe, 1.00.0000.0001 (English), 10/7/2008 23:23:46, 12800 bytes
   Driver: C:\WINDOWS\system32\kill.ini, 8/19/2008 18:39:18, 321 bytes
   Driver: C:\WINDOWS\system32\sfman32.dll, 6.00.0001.1368 (English), 10/7/2008 23:26:44, 10240 bytes
   Driver: C:\WINDOWS\system32\sfms32.dll, 6.00.0001.1368 (English), 10/7/2008 23:26:42, 108544 bytes
   Driver: C:\WINDOWS\system32\data\cts20x.dat, 10/7/2008 23:23:52, 2091 bytes
   Driver: C:\WINDOWS\system32\data\ctd20x.dat, 10/7/2008 23:23:52, 26919 bytes
   Driver: C:\WINDOWS\system32\data\CTP0460W.DAT, 10/7/2008 23:26:14, 275836 bytes
   Driver: C:\WINDOWS\system32\data\CTP0466W.DAT, 10/7/2008 23:26:14, 275836 bytes
   Driver: C:\WINDOWS\system32\data\CTP0463W.DAT, 10/7/2008 23:26:14, 276282 bytes
   Driver: C:\WINDOWS\system32\data\CTP0550W.DAT, 10/7/2008 23:26:14, 276094 bytes
   Driver: C:\WINDOWS\system32\data\CTP0678W.DAT, 10/7/2008 23:26:20, 357983 bytes
   Driver: C:\WINDOWS\system32\data\CTP0679W.DAT, 10/7/2008 23:26:14, 357983 bytes
   Driver: C:\WINDOWS\system32\data\CTP0464W.DAT, 10/7/2008 23:26:14, 275836 bytes
   Driver: C:\WINDOWS\system32\data\CTP0468W.DAT, 10/7/2008 23:26:16, 275836 bytes
   Driver: C:\WINDOWS\system32\data\CTP0465W.DAT, 10/7/2008 23:26:16, 275836 bytes
   Driver: C:\WINDOWS\system32\data\CTP0469W.DAT, 10/7/2008 23:26:16, 275836 bytes
   Driver: C:\WINDOWS\system32\data\CTP0730W.DAT, 10/7/2008 23:26:16, 277688 bytes
   Driver: C:\WINDOWS\system32\data\CTP0760W.DAT, 10/7/2008 23:26:16, 275257 bytes
   Driver: C:\WINDOWS\system32\data\CTP046AW.DAT, 10/7/2008 23:26:16, 275508 bytes
   Driver: C:\WINDOWS\system32\data\CTP046BW.DAT, 10/7/2008 23:26:16, 275508 bytes
   Driver: C:\WINDOWS\system32\data\CTP046CW.DAT, 10/7/2008 23:26:16, 275508 bytes
   Driver: C:\WINDOWS\system32\data\CTP0462W.DAT, 10/7/2008 23:26:18, 275836 bytes
   Driver: C:\WINDOWS\system32\data\CTP055AW.DAT, 10/7/2008 23:26:18, 275766 bytes
   Driver: C:\WINDOWS\system32\data\CTP073AW.DAT, 10/7/2008 23:26:18, 277688 bytes
   Driver: C:\WINDOWS\system32\data\CTXFIGM.RFX, 7/28/2006 10:31:42, 41320 bytes
   Driver: C:\WINDOWS\system32\data\CTXFIEM.RFX, 7/28/2006 10:31:40, 41788 bytes
   Driver: C:\WINDOWS\system32\data\CTXFICM.RFX, 7/28/2006 10:31:38, 41624 bytes
   Driver: C:\WINDOWS\system32\data\CTXFICBM.RFX, 6/23/2005 06:58:50, 7352 bytes
   Driver: C:\WINDOWS\system32\SBXFi.ico, 2/7/2005 17:45:22, 766 bytes
   Driver: C:\WINDOWS\system32\XFi.bmp, 2/7/2005 17:45:20, 3128 bytes
   Driver: C:\WINDOWS\system32\ctcoinst.dll, 3.00.0002.0047 (English), 10/7/2008 23:44:28, 86016 bytes
   Driver: C:\WINDOWS\system32\ctdvinst.dll, 0.05.0000.0047 (English), 10/7/2008 23:44:28, 181248 bytes
   Driver: C:\WINDOWS\system32\drivers\ctdvda2k.sys, 5.13.0001.0468 (English), 10/8/2008 01:21:54, 347080 bytes
     Name: NVIDIA nForce 590/570/550 Serial ATA Controller
Device ID: PCI\VEN_10DE&DEV_037F&SUBSYS_82231043&REV_A2\3&2411E6FE&0&6A
   Driver: C:\WINDOWS\system32\DRIVERS\nvata.sys, 5.10.2600.0666 (English), 4/24/2006 10:52:28, 100736 bytes
   Driver: C:\WINDOWS\system32\idecoi.dll, 1.00.0000.0001 (English), 4/24/2006 10:52:30, 289792 bytes
   Driver: C:\WINDOWS\system32\idecoiins.dll, 1.00.0000.0001 (English), 4/24/2006 10:52:30, 289792 bytes
   Driver: C:\WINDOWS\system32\NVCOI.DLL, 1.00.0000.0035 (English), 4/14/2006 07:01:20, 35840 bytes
Device ID: PCI\VEN_10DE&DEV_037F&SUBSYS_82231043&REV_A2\3&2411E6FE&0&69
Device ID: PCI\VEN_10DE&DEV_037F&SUBSYS_82231043&REV_A2\3&2411E6FE&0&68
     Name: PCI Standard-PCI-zu-PCI-Brücke
Device ID: PCI\VEN_10DE&DEV_0377&SUBSYS_00000000&REV_A2\3&2411E6FE&0&B8
   Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.5512 (German), 4/14/2008 03:02:13, 68224 bytes
Device ID: PCI\VEN_10DE&DEV_0376&SUBSYS_00000000&REV_A2\3&2411E6FE&0&90
Device ID: PCI\VEN_10DE&DEV_0375&SUBSYS_00000000&REV_A2\3&2411E6FE&0&B0
     Name: NVIDIA Network Bus Enumerator
Device ID: PCI\VEN_10DE&DEV_0373&SUBSYS_82231043&REV_A2\3&2411E6FE&0&88
   Driver: C:\WINDOWS\system32\DRIVERS\nvnetbus.sys, 1.00.0002.5521 (English), 3/22/2006 07:24:02, 18944 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\nvnrm.sys, 5.00.0005.5521 (English), 3/22/2006 07:23:40, 1068800 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\nvsnpu.sys, 5.00.0001.5521 (English), 3/22/2006 07:23:18, 261120 bytes
   Driver: C:\WINDOWS\system32\bdco1.dll, 1.00.0000.0000 (English), 3/22/2006 07:21:44, 10240 bytes
   Driver: C:\WINDOWS\system32\bdco1ins.dll, 1.00.0000.0000 (English), 3/22/2006 07:21:44, 10240 bytes
   Driver: C:\WINDOWS\system32\nvconrm.dll, 1.00.0000.0035 (English), 3/14/2006 14:45:22, 35840 bytes
Device ID: PCI\VEN_10DE&DEV_0373&SUBSYS_82231043&REV_A2\3&2411E6FE&0&80
Device ID: PCI\VEN_10DE&DEV_0370&SUBSYS_00000000&REV_A2\3&2411E6FE&0&70
Device ID: PCI\VEN_10DE&DEV_036E&SUBSYS_82231043&REV_A1\3&2411E6FE&0&60
   Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.5512 (German), 4/13/2008 19:40:29, 24960 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.5512 (English), 4/13/2008 19:40:30, 96512 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (German), 2/28/2006 13:00:00, 3328 bytes
     Name: Standard erweiterter PCI-zu-USB universeller Hostcontroller
Device ID: PCI\VEN_10DE&DEV_036D&SUBSYS_82231043&REV_A2\3&2411E6FE&0&51
   Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.5512 (English), 4/13/2008 19:45:35, 30208 bytes
   Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.5512 (English), 4/13/2008 19:45:36, 143872 bytes
   Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (German), 4/14/2008 03:22:31, 77312 bytes
   Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 4/13/2008 19:45:37, 59520 bytes
   Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.5512 (English), 4/14/2008 03:22:11, 7168 bytes
     Name: Standard OpenHCD USB-Hostcontroller
Device ID: PCI\VEN_10DE&DEV_036C&SUBSYS_82231043&REV_A1\3&2411E6FE&0&50
   Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.5512 (English), 4/13/2008 19:45:35, 17152 bytes
     Name: PCI Standard-RAM-Controller
Device ID: PCI\VEN_10DE&DEV_036A&SUBSYS_82231043&REV_A2\3&2411E6FE&0&4A
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0369&SUBSYS_CB8410DE&REV_A1\3&2411E6FE&0&40
   Driver: n/a
     Name: NVIDIA nForce PCI System Management
Device ID: PCI\VEN_10DE&DEV_0368&SUBSYS_82231043&REV_A2\3&2411E6FE&0&49
   Driver: n/a
     Name: PCI Standard-ISA-Brücke
Device ID: PCI\VEN_10DE&DEV_0360&SUBSYS_00000000&REV_A2\3&2411E6FE&0&48
   Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.5512 (German), 4/14/2008 02:58:03, 37632 bytes
Device ID: PCI\VEN_10DE&DEV_02FF&SUBSYS_02FF10DE&REV_A2\3&2411E6FE&0&05
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_02FE&SUBSYS_02FE10DE&REV_A2\3&2411E6FE&0&02
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_02FB&SUBSYS_00000000&REV_A1\3&2411E6FE&0&20
Device ID: PCI\VEN_10DE&DEV_02FA&SUBSYS_02FA10DE&REV_A2\3&2411E6FE&0&01
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_02F9&SUBSYS_02F910DE&REV_A2\3&2411E6FE&0&04
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_02F8&SUBSYS_02F810DE&REV_A2\3&2411E6FE&0&03
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_02F4&SUBSYS_02F410DE&REV_A2\3&2411E6FE&0&00
   Driver: n/a
     Name: NVIDIA GeForce 7950 GX2
Device ID: PCI\VEN_10DE&DEV_0294&SUBSYS_81FB1043&REV_A1\6&39E4382A&0&00080020
   Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0011.8122 (English), 1/15/2009 08:19:00, 6301248 bytes
   Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0011.8122 (English), 1/15/2009 08:19:00, 6168960 bytes
   Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0011.8122 (English), 1/15/2009 08:19:00, 163908 bytes
   Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0011.8122 (English), 1/15/2009 08:19:00, 663552 bytes
   Driver: C:\WINDOWS\system32\nvcuda.dll, 6.14.0011.8122 (English), 1/15/2009 08:19:00, 1560576 bytes
   Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0011.8122 (English), 1/15/2009 08:19:00, 9412608 bytes
   Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0011.8122 (English), 1/15/2009 08:19:00, 13680640 bytes
   Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0011.8122 (English), 1/15/2009 08:19:00, 86016 bytes
   Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0011.8122 (English), 1/15/2009 08:19:00, 81920 bytes
   Driver: C:\WINDOWS\system32\nvmccs.dll, 6.14.0011.8122 (English), 1/15/2009 08:19:00, 229376 bytes
   Driver: C:\WINDOWS\system32\nvmccsrs.dll, 6.14.0011.8122 (German), 1/15/2009 08:19:00, 45056 bytes
   Driver: C:\WINDOWS\system32\nvdisps.dll, 6.14.0011.8122 (English), 1/15/2009 08:19:00, 4710400 bytes
   Driver: C:\WINDOWS\system32\nvgames.dll, 6.14.0011.8122 (English), 1/15/2009 08:19:00, 3489792 bytes
   Driver: C:\WINDOWS\system32\nvmccss.dll, 6.14.0011.8122 (English), 1/15/2009 08:19:00, 188416 bytes
   Driver: C:\WINDOWS\system32\nvmobls.dll, 6.14.0011.8122 (English), 1/15/2009 08:19:00, 1286144 bytes
   Driver: C:\WINDOWS\system32\nvvitvs.dll, 6.14.0011.8122 (English), 1/15/2009 08:19:00, 3796992 bytes
   Driver: C:\WINDOWS\system32\nvwss.dll, 6.14.0011.8122 (English), 1/15/2009 08:19:00, 2744320 bytes
   Driver: C:\WINDOWS\system32\NvPVEnc.ax, 6.14.0011.8122 (English), 1/15/2009 08:19:00, 1253376 bytes
   Driver: C:\WINDOWS\help\nvcpl.hlp, 1/15/2009 08:19:00, 177897 bytes
   Driver: C:\WINDOWS\help\nvwcplen.hlp, 1/15/2009 08:19:00, 55444 bytes
   Driver: C:\WINDOWS\system32\nvcod.dll, 1.03.0007.0030 (English), 1/15/2009 08:19:00, 135168 bytes
   Driver: C:\WINDOWS\system32\nvcodins.dll, 1.03.0007.0030 (English), 1/15/2009 08:19:00, 135168 bytes
Device ID: PCI\VEN_10DE&DEV_0294&SUBSYS_81FB1043&REV_A1\6&2831AD2E&0&00000020
Device ID: PCI\VEN_10DE&DEV_027F&SUBSYS_027F10DE&REV_A2\3&2411E6FE&0&06
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_027E&SUBSYS_027E10DE&REV_A2\3&2411E6FE&0&07
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_01B3&SUBSYS_00000000&REV_A3\5&3CEB5A6&0&080020
Device ID: PCI\VEN_10DE&DEV_01B3&SUBSYS_00000000&REV_A3\5&3CEB5A6&0&000020
Device ID: PCI\VEN_10DE&DEV_01B3&SUBSYS_00000000&REV_A3\4&13D46659&0&0020
     Name: Silicon Image SiI 3132 SATALink Controller
Device ID: PCI\VEN_1095&DEV_3132&SUBSYS_819F1043&REV_01\4&2A4D88F&0&00B0
   Driver: C:\WINDOWS\system32\DRIVERS\SI3132.sys, 1.00.0000.0009 (German), 1/20/2005 07:30:52, 67200 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\SiWinAcc.sys, 1.00.0000.0011 (German), 11/2/2004 04:21:32, 10368 bytes
   Driver: C:\WINDOWS\system32\SilSupp.cpl, 3.00.0000.0018 (German), 1/12/2005 03:56:46, 78336 bytes
     Name: Texas Instruments OHCI-konformer IEEE 1394-Hostcontroller
Device ID: PCI\VEN_104C&DEV_8023&SUBSYS_815B1043&REV_00\4&1CEFD014&0&5870
   Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.5512 (English), 4/13/2008 19:46:18, 61696 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.5512 (English), 4/13/2008 19:46:18, 53376 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.5512 (English), 4/13/2008 19:51:25, 61824 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.5512 (English), 4/13/2008 19:51:25, 60800 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 13:46:40, 6400 bytes
     Name: PCI Standard-Host-CPU-Brücke
Device ID: PCI\VEN_1022&DEV_1103&SUBSYS_00000000&REV_00\3&2411E6FE&0&C3
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_1102&SUBSYS_00000000&REV_00\3&2411E6FE&0&C2
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_1101&SUBSYS_00000000&REV_00\3&2411E6FE&0&C1
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_1100&SUBSYS_00000000&REV_00\3&2411E6FE&0&C0
   Driver: n/a
DirectX Components
   ddraw.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:08 279552 bytes
 ddrawex.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:08 27136 bytes
   dxapi.sys: 5.01.2600.0000 English Final Retail 2/28/2006 13:00:00 10496 bytes
    d3d8.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:08 1179648 bytes
 d3d8thk.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:08 8192 bytes
    d3d9.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:08 1689088 bytes
   d3dim.dll: 5.01.2600.0000 English Final Retail 2/28/2006 13:00:00 436224 bytes
d3dim700.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:08 824320 bytes
 d3dramp.dll: 5.01.2600.0000 English Final Retail 2/28/2006 13:00:00 590336 bytes
   d3drm.dll: 5.01.2600.0000 English Final Retail 2/28/2006 13:00:00 350208 bytes
  d3dxof.dll: 5.01.2600.0000 English Final Retail 2/28/2006 13:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 2/28/2006 13:00:00 34816 bytes
   dplay.dll: 5.00.2134.0001 German Final Retail 2/28/2006 13:00:00 33040 bytes
  dplayx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 229888 bytes
dpmodemx.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 24064 bytes
 dpwsock.dll: 5.00.2134.0001 English Final Retail 2/28/2006 13:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 57856 bytes
dplaysvr.exe: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:43 29696 bytes
  dpnsvr.exe: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:43 17920 bytes
   dpnet.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 375296 bytes
dpnlobby.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:20:27 3072 bytes
 dpnaddr.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:20:27 3072 bytes
 dpvoice.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 214016 bytes
dpvsetup.exe: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:43 83456 bytes
  dpvvox.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 116736 bytes
  dpvacm.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 21504 bytes
dpnhpast.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 35328 bytes
dpnhupnp.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 60928 bytes
dpserial.dll: 5.00.2134.0001 German Final Retail 2/28/2006 13:00:00 54032 bytes
  dinput.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 163328 bytes
 dinput8.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 186368 bytes
   dimap.dll: 5.01.2600.0000 English Final Retail 2/28/2006 13:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 German Final Retail 2/28/2006 13:00:00 395264 bytes
     joy.cpl: 5.03.2600.5512 German Final Retail 4/14/2008 03:23:07 69632 bytes
   gcdef.dll: 5.01.2600.0000 German Final Retail 2/28/2006 13:00:00 78336 bytes
     pid.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:23 35328 bytes
  dsound.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 367616 bytes
dsound3d.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 1293824 bytes
  dswave.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 19456 bytes
   dsdmo.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 181248 bytes
dsdmoprp.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 74240 bytes
  dmusic.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 104448 bytes
  dmband.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 28672 bytes
dmcompos.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 61440 bytes
   dmime.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 181248 bytes
dmloader.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 35840 bytes
 dmstyle.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 105984 bytes
 dmsynth.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 103424 bytes
dmscript.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 82432 bytes
  system.dll: 1.01.4322.2407 English Final Retail 10/4/2008 02:00:45 1232896 bytes
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 2/23/2009 13:37:14 473600 bytes
Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 2/23/2009 13:37:12 2676224 bytes
Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 2/23/2009 13:37:12 2846720 bytes
Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 2/23/2009 13:37:12 563712 bytes
Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 2/23/2009 13:37:12 567296 bytes
Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 2/23/2009 13:37:12 576000 bytes
Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 2/23/2009 13:37:13 577024 bytes
Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 2/23/2009 13:37:13 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 2/23/2009 13:37:13 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 2/23/2009 13:37:13 578560 bytes
Microsoft.DirectX.Direct3DX.dll: 9.12.0589.0000 English Final Retail 2/23/2009 13:37:14 578560 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 2/23/2009 13:37:14 145920 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 2/23/2009 13:37:14 159232 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 2/23/2009 13:37:14 364544 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 2/23/2009 13:37:14 178176 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 2/23/2009 13:37:14 53248 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 2/23/2009 13:37:14 12800 bytes
Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 2/23/2009 13:37:13 223232 bytes
   dx7vb.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 619008 bytes
   dx8vb.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 1227264 bytes
 dxdiagn.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 2113536 bytes
   mfc40.dll: 4.01.0000.6140 English Final Retail 2/28/2006 13:00:00 924432 bytes
   mfc42.dll: 6.02.4131.0000 English Final Retail 4/14/2008 03:22:14 1028096 bytes
 wsock32.dll: 5.01.2600.5512 German Final Retail 4/14/2008 03:22:32 24576 bytes
amstream.dll: 6.05.2600.5512 English Final Retail 4/14/2008 03:22:07 70656 bytes
 devenum.dll: 6.05.2600.5512 German Final Retail 4/14/2008 03:22:08 59904 bytes
  dxmasf.dll: 6.04.0009.1133 German Final Retail 4/14/2008 03:22:09 500278 bytes
mciqtz32.dll: 6.05.2600.5512 German Final Retail 4/14/2008 03:22:14 35328 bytes
 mpg2splt.ax: 6.05.2600.5512 English Final Retail 4/14/2008 03:23:07 148992 bytes
   msdmo.dll: 6.05.2600.5512 English Final Retail 4/14/2008 03:22:16 14336 bytes
  encapi.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:10 20480 bytes
    qasf.dll: 11.00.5721.5145 English Final Retail 10/18/2006 21:47:18 211456 bytes
    qcap.dll: 6.05.2600.5512 German Final Retail 4/14/2008 03:22:23 192512 bytes
     qdv.dll: 6.05.2600.5512 German Final Retail 4/14/2008 03:22:23 279040 bytes
    qdvd.dll: 6.05.2600.5512 German Final Retail 4/14/2008 03:22:23 387072 bytes
   qedit.dll: 6.05.2600.5512 German Final Retail 4/14/2008 03:22:23 563200 bytes
qedwipes.dll: 6.05.2600.5512 English Final Retail 4/13/2008 18:21:32 733696 bytes
  quartz.dll: 6.05.2600.5596 German Final Retail 5/7/2008 06:10:35 1293824 bytes
 strmdll.dll: 4.01.0000.3936 German Final Retail 4/14/2008 03:22:30 246814 bytes
 iac25_32.ax: 2.00.0005.0053 English Final Retail 4/14/2008 03:23:07 199680 bytes
  ir41_32.ax: 4.51.0016.0003 English Final Retail 4/14/2008 03:23:07 848384 bytes
 ir41_qc.dll: 4.30.0062.0002 English Final Retail 4/14/2008 03:22:12 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 4/14/2008 03:22:12 338432 bytes
 ir50_32.dll: 5.2562.0015.0055 English Final Retail 4/14/2008 03:22:12 755200 bytes
 ir50_qc.dll: 5.00.0063.0048 English Final Retail 4/14/2008 03:22:12 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 4/14/2008 03:22:12 183808 bytes
   ivfsrc.ax: 5.10.0002.0051 English Final Retail 4/14/2008 03:23:07 154624 bytes
mswebdvd.dll: 6.05.2600.5512 German Final Retail 4/14/2008 03:22:18 205312 bytes
      ks.sys: 5.03.2600.5512 German Final Retail 4/13/2008 21:16:36 141056 bytes
  ksproxy.ax: 5.03.2600.5512 German Final Retail 4/14/2008 04:23:08 129536 bytes
  ksuser.dll: 5.03.2600.5512 German Final Retail 4/14/2008 04:22:14 4096 bytes
  stream.sys: 5.03.2600.5512 German Final Retail 4/13/2008 20:45:16 49408 bytes
mspclock.sys: 5.03.2600.5512 German Final Retail 4/13/2008 19:39:50 5376 bytes
   mspqm.sys: 5.01.2600.5512 German Final Retail 4/13/2008 19:39:51 4992 bytes
 mskssrv.sys: 5.03.2600.5512 German Final Retail 4/13/2008 19:39:52 7552 bytes
  swenum.sys: 5.03.2600.5512 German Final Retail 4/13/2008 19:39:53 4352 bytes
mpeg2data.ax: 6.05.2600.5512 English Final Retail 4/14/2008 03:23:07 118272 bytes
msvidctl.dll: 6.05.2600.5512 German Final Retail 4/14/2008 03:22:18 1433088 bytes
  vbisurf.ax: 5.03.2600.5512 English Final Retail 4/14/2008 03:23:07 30208 bytes
   msyuv.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:18 16896 bytes
wstdecod.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:32 51200 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMA Voice Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.5596
CT Upsampler filter,0x00100000,1,1,Upsample.ax,2.00.0005.0000
Creative Wave Writer,0x00200000,1,0,WavWrite.ax,3.01.0004.0000
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.5512
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.5596
WM ASF Reader,0x00400000,0,0,qasf.dll,11.00.5721.5145
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.5721.5145
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.5596
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.5596
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
BPM Metadata,0x001fffff,1,1,MetaBPMu.ax,2.00.0002.0000
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
Creative Recording Wav_Asio Filter,0x00400000,0,1,AudioRec.ax,1.00.0002.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
CT Time-Scaling filter,0x00100000,1,1,TimeScal.ax,2.03.0009.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.5512
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5596
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
DivX for Blizzard Decoder Filter,0x00800000,1,1,blizzard.ax,5.00.0002.0000
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.5596
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.5596
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.5512
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5596
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.5596
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,11.00.5721.5145
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.5512
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.5596
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
PCM to EXT,0x00200000,0,0,Pcm2Ext.ax,6.00.0002.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
CT Karaoke filter,0x00100000,1,1,Karaoke.ax,2.00.0012.0000
Creative AC3 Source Filter,0x00400000,0,1,AC3Srcu.ax,3.02.0001.0000
Creative PCM Raw Writer,0x00200000,1,0,RawWritu.ax,1.00.0000.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
NSC file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
CT PDP filter,0x00100000,1,1,PDP.ax,1.00.0008.0000
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.5596
CoreAAC Audio Decoder,0x00800000,1,1,CoreAAC.ax,1.02.0000.0573
Windows Media source filter,0x00600000,0,2,wmpasf.dll,11.00.5721.5145
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5596
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.5512
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.5512
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.5596
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.5512
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.5596
CT SmartVolumeManagement filter,0x00100000,1,1,DSCompr.ax,1.00.0008.0000
Creative Audio Gain Filter,0x00200000,1,1,AudGain.ax,1.00.0000.0000
WM ASF Writer,0x00400000,0,0,qasf.dll,11.00.5721.5145
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.5512
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
Creative Flac Source Filter,0x00400000,0,1,FlacSrcu.ax,1.00.0002.0000
File writer,0x00200000,1,0,qcap.dll,6.05.2600.5512
Creative MLP Source Filter,0x00400000,0,1,MlpSrcu.ax,3.01.0000.0000
Creative File Reader Filter,0x00400000,0,1,FilReadu.ax,1.00.0005.0000
SVM Metadata,0x001fffff,1,1,MetaSVMu.ax,2.00.0002.0000
CT HPVirtualizer filter,0x00100000,1,1,Virtual.ax,1.00.0000.0000
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
Avi Splitter,0x00600001,1,1,AviSplitter.ax,1.00.0000.0007
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.5512
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.5512
CT CMSS3 filter,0x00100000,1,1,CMSS3.ax,3.00.0013.0000
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.5596
.RAM file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
Creative Ogg Source Filter,0x00400000,0,1,OggSrcu.ax,1.00.0001.0000
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.5512
Creative NVF Filter,0x00400000,0,1,NvfSrcu.ax,3.01.0001.0000
DTS/AC3 Source,0x00400000,0,1,dtsac3source.ax,1.00.0000.0000
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
Noise Reduction,0x00100000,1,1,NoisRedu.ax,3.00.0007.0000
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF URL Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.5512
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.5512
Creative WMA Writer,0x00200000,1,0,WMAWrite.ax,5.00.0001.0000
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.5512
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.5512
Creative WMA Source Filter,0x00400000,0,1,WmaSrc.ax,3.01.0001.0000
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.5512
Avi Source,0x00600001,0,0,AviSplitter.ax,1.00.0000.0007
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5596
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.5596
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.5596
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.5596
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.5596
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.5596
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.5596
XML Playlist,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.5512
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.5596
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.5596
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.5596
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Creative CDDA Source Filter,0x00400000,0,1,CDDA.ax,3.00.0003.0000
Creative LiveRecording Filter SxS,0x00400000,0,1,LiveRecu.ax,5.00.0001.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Creative Internet Source Filter,0x00400000,0,1,InetSrcu.ax,1.00.0000.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.5512
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5596
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.5596
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming-Daten-Transforms:
Microsoft Kernel-Echounterdrückung,0x00000000,0,0,,
Microsoft Kernel GS Wavetablesynthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel-DLS-Synthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel-DRM-Audioentschlüsselung,0x00200000,1,1,,5.03.2600.5512
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.5512
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.5596
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.5512
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel IYUV Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.5512
Audio Compressors:
WMA Voice Encoder DMO,0x00600800,1,1,,
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.5596
Lernout & Hauspie CELP 4.8kbit/s,0x00200000,1,1,quartz.dll,6.05.2600.5596
Lernout & Hauspie SBC 8kbit/s,0x00200000,1,1,quartz.dll,6.05.2600.5596
Lernout & Hauspie SBC 12kbit/s,0x00200000,1,1,quartz.dll,6.05.2600.5596
Lernout & Hauspie SBC 16kbit/s,0x00200000,1,1,quartz.dll,6.05.2600.5596
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5596
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5596
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.5596
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.5596
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.5596
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.5596
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.5596
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.5596
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.5596
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.5596
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.5596
Audio Capture Sources:
SB X-Fi Audio [8C00],0x00200000,0,0,qcap.dll,6.05.2600.5512
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.5596
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.5596
SB X-Fi Synth A [8C00],0x00200000,1,0,quartz.dll,6.05.2600.5596
SB X-Fi Synth B [8C00],0x00200000,1,0,quartz.dll,6.05.2600.5596
WDM Streaming-Capturegeräte:
SB X-Fi Audio [8C00],0x00200000,3,2,,5.03.2600.5512
WDM Streaming-Wiedergabegeräte:
SB X-Fi DMusic Synth [8C00],0x00200000,1,1,,5.03.2600.5512
SB X-Fi Synth A [8C00],0x00200000,1,1,,5.03.2600.5512
SB X-Fi Synth B [8C00],0x00200000,1,1,,5.03.2600.5512
BDA Transport Information Renderers:
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,
WDM Streaming-Mixer:
Microsoft Kernel-Waveaudiomixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.5512
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.5512
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.5512
Audio Renderers:
SB X-Fi Audio [8C00],0x00200000,1,0,quartz.dll,6.05.2600.5596
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.5596
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.5596
DirectSound: SB X-Fi Audio [8C00],0x00200000,1,0,quartz.dll,6.05.2600.5596
WDM Streaming-Systemgeräte:
SB X-Fi Synth A [8C00],0x00200000,8,2,,5.03.2600.5512
SB X-Fi Audio [8C00],0x00200000,10,2,,5.03.2600.5512
3,184 views 1 replies
Hrothgaar:
Sorry about your troubles.  The 2nd issue is not in fact a bug - the game is designed so that you don't have 3 different voices talking in your ear at the same time.  So sometimes you will not hear notifications because there is already one playing.  You should still get the event information in your event window (lower left) though.
The 1st issue: it sounds like your computer is having a few problems keeping up with all the work it needs to do.  When it gets overloaded, the sound will crack a bit because it isn't able to fill the sound buffer in time.  Do you have anything major running in the background? or something that does periodic updating?  Make sure that you don't have too much stuff running in the background.  Also, you may want to disable bloom and turn down your graphics settings (in Effects menu) to see if that helps.
Did you have this problem with original Sins?
