Need a little help with system color configuration
Could anyone tell me which one of the system colour setting applies to the start menu items?
Specifically the colour that flashes, say, for when you receive a message on msn?
3,720 views 3 replies
Failing that, can anyone point me in the direction of an indepth tutorial on the "Change system colors" part of Windowblinds?
Do you mean taskbar, the flashing taskbar button is an image not a system color. You would need to edit image using SkinStudio and a graphics app.
Not sure there is one.
Most of the system colors are for unskinned classic style dialogs and buttons.
Could anyone tell me which one of the system colour setting applies to the start menu items?Specifically the colour that flashes, say, for when you receive a message on msn?Do you mean taskbar, the flashing taskbar button is an image not a system color. You would need to edit image using SkinStudio and a graphics app.Failing that, can anyone point me in the direction of an indepth tutorial on the "Change system colors" part of Windowblinds?Not sure there is one.Most of the system colors are for unskinned classic style dialogs and buttons.
Looks like I'll have to go take a peek at SkinStudio... thanks for the info :)
Edit: All sorted, thanks:)
+1 Karma to you sir
