Problems with scrolling / Probleme mit scrollen, Starting Position in Random Map / Startposition in Zufallskarte
Hy Community
1.
Yesterday i had a problem with scrolling the map. If my starting planet take place on the (in my cause) right site of the map, i can't scroll my map to this site. Example: I look at my planet and want to scroll to the next planet a little bit more in the right site. I can't! I have to zoom out an zoom in on this next planet. Any ideas? Scroll on the left site is no problem in if my starting planet is somewhere in the middle of the universe ==> no problem.
2.
Can I somehow define my starting position in a random map? If I play in a hugh universe (five systems) with 5ive other players, all six parts find place in two of five systems. The other three systems are empty... it's always on this way.
Greets
Hallo Community
1.
Gestern hatte ich ein Problem mit dem Scrollen der Karte. Wenn mein Startplanet am rechten Rand der Karte ist, und ich noch etwas weiter nach rechts zum nächsten Planeten (der halt noch etwas weiter rechts ist) scrollen will, tut sich nichts. Link scrollen ist kein Problem und das passiert auch nur, wenn mein Startplanet ganz am rechten Rand ist... Ideen?
2.
Kann ich irgendwie meine Startposition in einer Grossen Zufallskarte (fünf Systeme) auswählen? Wenn ich mit fünf Gegner spiele, sind alle sechs Parteien immer auf zwei Systeme verteilt. Die anderen drei Systeme sind dann immer leer.
Gruss
6,851 views 2 replies
I have also experienced this problem a cuple of times.
It appears that the randomly generated systems, sometimes create a planet that is outside the scrollable game area.
hence when you are trying to scroll with the arrows they will not work in a certain direction (or two directions, ie my planet was bottom right corner of the map, can't scroll right or down.).
The planet (and anything in its gravity well) can only be reached by hovering the mouse then zoom in/out.
1. I'm not sure why you have more problem with the right side than the left, but it is normal to have to zoom out to see other planets. Scrolling while being zoomed in takes too long.
2. I've noticed this too, all the factions are bunched up in a couple of systems and the other are free. Probably like "new world" regions to explore and conquer without neighbors (if you get there first).
