HELP! DeskScapes 1.02 problem (possible)
Desktop icon labels disappear
Ever since I installed DescScapes 1.02, whenever I reboot, or just re-login, my desktop icon labels disappear.
I have tried a number of things to resolve the issue, but with no luck.
If the text is missing and I switch to a non-animated desktop, the text shows up, but without any drop shadows.
I checked the performance setting for it, and it was still turned on.
I found that if the text disappears, I have to switch to a non-animated desktop; reboot; then switch back to DeskScapes.
Then the text is there, at least for a while. If I play a game that is full-screen, when I go back to windows, the text is gone again.
Anyone have any idea how to fix this????
6,203 views 4 replies
Do you still have 1.01 to go back and see if it still happens?
I've noticed the exact same issue. But, if I selected a plain color background then go back to display properties and re-select the dream, they stayed visible. But I've had to do this on several occasions and have not figured a rhyme or reason for it.
No O.K. and cancel buttons work.No chance to change a dream.Big Bullshit Program. Seems too me taking money for nothing and do not give a shit about their customers suits them enough. Trouble since i startet the shit.
If you have a problem with deskscapes please report it to [email protected]
Please note that problems with VIDEO dreams (vs dynamic ones) are usually video driver / video codec problems.
