we have a objectdock system tray problem
I can't see any icon in the system tray tab
everything is ok but i can't see any icon in the tabbed system tray.
my configuration;
xp home 32 bit - "NON ENGLISH" !!
sdmcp.exe - running
sdcentral - installed
enable mcp notification area support - checked
Any sugestions for this bugs? Pls help me
(repeatdly i clear cache and uninstall - re-install sdcentral and od+)
21,764 views 28 replies
Try this:  Stardock MCP download
Thanks zubaz but
we have C:\Program Files\Common Files\Stardock\sdmcp.exe and i'm copied shurtcut to startup folder and restart to computer.
But now I can't see any icon in the system tray tab.
Does the system tray not work on OD Plus with non english windows ?
I use Win XP pro french version and got no problems.
Did you try to launch the sdmcp.exe? by a couple of click
sdmcp.exe - running (in task manager)
Did you reboot?
SDMCP hooks into the systray early in the boot process.  Without reboot . . nuthin.
Make sure you are running the latest OD. First gen versions did not have systray support for Vista. Only the latest v1.9 version does.
Did you reboot?
I'm try it but again i can't see any icon in the system tray tab.
I was using the objectdock. After uninstall and delete objectdock, and clear the cache.
After install stardockcentral , install OD+ and install mp102.exe.
I have C:\Program Files\Common Files\Stardock\sdmcp.exe and i'm copied shurtcut to startup folder, I'm Run the sdmcp.exe and restart to computer.
sdmcp.exe - running
(i try uncheck it but again i can't see any icon in the system tray tab.)
What's wrong ? where is the problem ?
pls help...
i'm using windows xp pro SP2 and i check the version = OD+ v1.90
and i can't see any icon in tabbed dock system tray
mymooncuk - perhaps it may be better to contact [email protected] and open a trouble ticket. They will be able to assist you in resolving this issue.
you should mail all your infos to [email protected]
Version used language OS
With your email of purchase
and link to this tread as well
You will get certainly more help
OD+ v1.9 does NOT need SDMCP, but ObjectBar and DesktopX DO. Turn it off (with SDC) if OD+ is the only app that you want tray icons for.
Same problem also here with OD 1.90, Win XP SP 2 French.
No icons in the system tray. Same problem as fellows above.
If problem has been corrected/solved/fixed through any manipulation, could you also post here so we won't all bother the stardock support.
Thanks!
CalimeroQueen (sorry guys french it's better to explain between frenchies )
Premièrement, Avez-vous la version plus d'OD? Parce-que le system tray est une options de la version Plus seulement....
j'ai la meme config et ici çà fonctionne, avez-vous Stardock Central? Si oui ouvrez le allez dans "tools", "generals settings" et cochez la case "Enable MCP notification area support". Si elle est déjà cochée, download sdmcp et installez le. après un redémarrage de l'ordinateur cela devrait fonctionner.
Sinon essayez de désinstaller OD, telecharger Stardock Central et d'installer OD ou OD+ depuis SDC. et de recocher la case de mcp dans SDC et de telecharger SDMCP.
Si rien de tout çà fonctionne le mieux c'est d'envoyer un mail à [email protected]
Quentin, sorry but you are wrong, OD + 1.9 doesn't need neither Stardock Central nor SDMCP...
I'm using an object tray docklet by Melchior Moos to have a system tray while I wait to see if stardock solves my problem.
never said OD+ need SDC to run but i said that a clear install via SDC could solve a part of the problem. For SDMCP yes OD+ don't need it or ....
I hadn't the systray to run on OD+ but once i have install SDMCP (and copy past all files .dll found on C:\Program Files\Fichiers communs\stardock C:\Program Files\Common files\stardock in OD folder and also DX and OB) never get the problems
I was wondering if that could help SD but like it's a little bite unorthodox and like everybody said that OD+ don't need SDMCP...i don't said it before.
I can say for experience that it doesn't solve the problem, because it was the first thing that I've tried...
Thanks for the answers.
Thanks also for your help but I also tried all these things with no success (and yes, I've OD+). I downgraded to 1.5 which works at the moment. I'll wait for a fix or a new version to try again. Thanks.
But 1.5 *does* use SDMCP!
Are you sure that when you have 1.9 loaded that SDMCP is *not* running?
Note that SDMCP is not launched from the 'usual' startup locations !!! - SDC is the most convenient way to disable it because of that.
hey... i got it to work... but i install v1.9 then reinstall and override directory with v1.5... only two icons appeared so i tho till restarted the comp... it worked for me hehehe
