Problem with Alenware Xenomorph skin!! PLEASE HELP!
PLEASE HELP ASAP! please!
I have the alienware xenomorph skin and the scrollbar is the same, for some reason. In the preview, it's supposed to change to some 'glassy' scrollbar. Instead, it is the boxy (not win xp default) old classic scrollbar! HOW DO I FIX THIS? Someone please help!
4,825 views 3 replies
The trial version of WindowBlinds does not skin scrollbars.
It fixed ONE scrollbar... The one where you go to my computer and single-click on the 'local drive' icon... it gives you the menu on the left... the scrollbar for that one is what the theme says it should be... but my IE scrollbar and the normal one are not fixed! What's the problem?
Are you using the "trial" version of WindowBlinds?
