Help! Titlebar button problem!
Why are they overlapping?
I have recently applied a new theme from a msstyle and noticed that the window frame buttons (minimize, maximize,close) were a bit off. I mean I could hover the mouse over the maximize button and the minimize button will be highlighted and pressed instead.
I have opened the theme in skinstudio and noticed that the buttons have flashing rectangles around them, I assume it's the area where you need to click. They overlap.I opened the .tga files of the buttons, and there was a lot of empty pink space which seemed to be causing the problem. I cropped the images and now the flashing boxes constrain to them. However, I now have this even worse problem
What can I do?
(they are not perpixel btw)
1,537 views 0 replies
